Originally Posted by SeaDog
I don't see that as a real problem many times durning mfg springs get a little twist in them. You could take the rig to a spring shop and have them install spring clips on both ends which would stop any side to side movement, this is done on springs that have allot of movement from loaded to unloaded and units with many leafs. JMHO
Thank you for the reply. I will look again today at the rig and see what I can see on a closer inspection.
I am going to try to tap the spring back in position. I will watch to see how loose it is. If it moves to easily then I will need to have a shop align and tighten and put on spring clips. If it move hard then I will watch it for future movement. If it moves again or can not be hammerer I will take it to a spring shop.
I also realized that I did not look at the same tire as the spring was out of alignment, I went to the front axle, a whole nother spring system. I will check the front spring today and am willing to be that the spring will be out of alignment as much as the back.
Boy I bet that is clear as mud.
Again Thank You, for your reply, as it made the light bulb go off over my head. You may have seen the flash ;^).
