Originally Posted by Chuck_S
Tire capacity is directly linked to tire pressure regardless of vehicle or trailer application.
My point was on the tow vehicle tires are not the determining factor of vehicle capacity. Axles and suspension will have less capacity -- or else we couldn't run the tires soft for a nicer ride. Trailer tires are often what determines the vehicle capacity and inflating to anything less than maximum sidewall pressure serves no purpose and increases risk.
-- Chuck
I've tried to keep away from a long explanation about this but it's becoming unavoidable.
Your right, the vehicle GVWR is it's limiter. How the GAWRs and tire load capacities are determined by the vehicle manufacturer differs because of regulation factors. For the tow vehicle (FMVSS certified) the axles provide the vehicle's major load capacity reserves. If you will notice, your TV will have combined GAWR axle loads greater than the vehicle GVWR. That allows the axles to provide load capacity reserves. Tires fitted to those certified axles MUST provide a load capacity that supports the maximum axle load. Then the FMVSS throws the vehicle manufacturer a bone by saying it's their determination to insure the tires are
appropriate for that fitment. They are free to advertise the vehicle any way they want to but they MUST follow FMVSS guidelines for they are
minimum requirements.
For RV trailer tire fitments there is no provision in the FMVSS for the vehicle manufacturer to provide tires with more load capacity than the vehicle certified GAWR limits. Again, when the trailer manufacturer certified the trailer, they determined those tires on the trailer are appropriate.
For RV trailer model years 2017 and newer, you have a 98% chance of seeing tires on them with at least 10% in load capacity reserves, thanks to RVIA. Maybe in the next NHTSA tire rules committee meeting the issue of tire load capacity reserves for RV trailer fitments will be addressed and some action taken to insure a minimum load capacity reserve is provided for those tires..
