Old 01-07-2023, 09:17 PM   #1
Tire Blow Out Protection
I haven't seen a posting about this product called RV De-Defender. It is a metal shield that is mounted behind the brake assembly and covers the tire with a heavy gauge metal shield. If the tire blows it contains the flying and flapper remains of your tire from tearing up the TT.
Here is a link to the products web site:
https://rv-de-fender.com
More information and contact info can be found on their Facebook page
https://www.facebook.com/rvdefender1
Don't see any information on the web site as for pricing and availability. Per the web site available in size up to fit 5000-7000lb axles with 16” wheels. Install not a simple bolt on as you need to remove both the tire and brake drum assembly but doable if your handy. Looks like they are working on TT with disc brakes and tripe axle MORryde type suspension.
Curious what you folks think.
2022 Rockwood 2893BS
2019 Ram 2500 Longhorn CTD
Theb2b is offline   Reply With Quote
Old 01-07-2023, 09:42 PM   #2
NMWildcat's Avatar
Would have to see the price they are wanting, but I'm definitely skeptical.
I see the need for some sort of protection for most RVs as I had one tire failure that cost my insurance $8k.
I've seen blowouts destroy flatbed decking that was 2"x12" wood covered by 3/16" diamond decking. Have you seen the stock trailer fenders after a blowout? And most are the same thickness as these devices.
Guess I would have to see this for myself. And seems like when you have to call for a price, it is too much
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
NMWildcat is online now   Reply With Quote
Old 01-07-2023, 10:21 PM   #3
That thing is kinda like something I made. My main reason for making it was to deflect water from slinging up into my slide. After building it, I thought it would help in the event of a blowout, too. I made it using a galvanized basement window well
[IMG][/IMG]
2012 Cedar Creek 36CKTS Touring Edition
2015 Ford F-350 CC DRW Lariat
Joe_GA is offline   Reply With Quote
Old 01-07-2023, 10:41 PM   #4
NXR
NXR's Avatar
Google Dorking found some pricing but I have no way to know if it's still current.
https://rv-de-fender.com/product/tri...15-inch-wheel/
https://rv-de-fender.com/product/tan...ft-kit-bundle/
https://rv-de-fender.com/product/sin...15-inch-wheel/
Ray
2020 Georgetown GT5 34H5
NXR is online now   Reply With Quote
Old 01-08-2023, 06:19 AM   #5
Steve & Linda M.
MevetS's Avatar
Article just out today : https://camperreport.com/rv-defender/ .
Started in the "Pumpkin" '79 Burnt Orange Dodge "Street Van" ... NW cruise, Canadian Rockies, Round trip to Alaska. Then' 94 Tioga Montara, '06 Jayco Jay Flight 5th Wheel. Workmanship decline started : '15 Thor Siesta & '17 Tiffin Breeze.
Another RV learning experience with our 2022 34KD Force.
2019 Jeep KL (Cherokee) TOAD
MevetS is offline   Reply With Quote
Old 01-08-2023, 06:33 AM   #6
ysidive
ysidive's Avatar
Fender protection
Originally Posted by NXR View Post
If those prices are fairly accurate, I do not think that their sales will keep them in business long. Just too high of a price....
2018 Duramax 2500 LTZ
Freedom Express 281rlds
Days Camping 2021 46 Days
Days Camping 2022 Not Enough
ysidive is offline   Reply With Quote
Old 01-08-2023, 07:31 AM   #7
NMWildcat's Avatar
Yep, very expensive. And the marketing seems over the top. Lots of disaster pics of what could happen to an RV during a tire failure, no pictures of the product after a test of a tire failure.
I'm going with my thoughts of this being another over marketed product that has limited benefit.
Old 01-08-2023, 06:20 PM   #8
KB1
Blowouts
I like the homemade version and will probably look into that a bit in the early spring. We bought Tire Minders and rely on them for early warning. Not perfect but better than hoping.
KB1 is offline   Reply With Quote
Old 01-08-2023, 09:02 PM   #9
Rv defender cost
I found some prices online. Not sure how accurate/old they are…
Single axle $999
Double axle $1750-$1999
Srockey is offline   Reply With Quote
Old 01-08-2023, 09:12 PM   #10
I think I'll stick with good tires, regular inspection, a TPMS system, no overloading, sensible speeds, and carry insurance.
Price of shields for my trailer is same as two full sets of GY Endurance tires with $$ left over.
Sent from my SM-N950U1 using Forest River Forums mobile app
2023 f-150 SCREW XLT 3.5 Ecoboost (The result of a $68,000 oil change)
TitanMike is offline   Reply With Quote
Old 01-19-2023, 07:28 PM   #11
Their web site states that the curved portion is made out of 14 ga (.0747) thick steel. Not too thick.
Elcheapo is offline   Reply With Quote
Old 01-19-2023, 08:02 PM   #12
I doubt it will prevent damage if a tire throws it's entire tread. I had that happen to a utility truck at 70, and it caved in the bottom of the left rear cabinet, took out the fuel fill pipe, AND put an inverted dent in the rear diamond plate bumper. I actually felt it lift the rear of the truck. The tire didn't go flat but it threw its entire cap.The bumper alone was heavier steel than what those shields seem to be made of.
Maybe it would contain a lighter trailer tire, but I'd save the coin as opposed to that mod.
2020 Sunseeker 2860DS
n1acguy is offline   Reply With Quote
Old 01-19-2023, 08:12 PM   #13
Old Eeyore's Avatar
Might as well cut a Farm Stock Tank down the middle. Not near as thick but 1/4 the cost. That would have provided at least some protection for my electric and gas lines under my slide-out when I had a blow-out a few years ago.
Realistically I'm afraid it would take some really serious steel to protect from the force of a tire coming apart. Worked in an auto shop for several years and saw first hand that not even 50's/60's cars could stand up to that.
2022 Rockwood 2608BS / 2019 Silverado 1500
2016 Rockwood Roo 23IKSS / 2019 Silverado 1500
2011 Rockwood Roo 21SS / 2011 Tahoe
2006 Fleetwood Bayside / 2006 4Runner
1999 Coleman SantaFe / 2001 Sienna
1967 Nimrod / 1998 Outback
Old Eeyore is offline   Reply With Quote
Old 01-19-2023, 10:09 PM   #14
Did anyone ever observe the cage used at tire shops when inflating truck tires? It is a generous number of 2" steel bars. I don't think 14 Ga steel will slow down a thrown tread one bit.
I like an earlier post,..... check tire pressure regularly, use a TPMS, don't overload, check and replace tires based on age, don't speed in excess of posted speed limits, and pay attention to road debris by not following too close to the vehicle ahead.
Bob
Bob K4TAX is online now   Reply With Quote
Old 01-20-2023, 08:19 AM   #15
Very sceptical as well. This video is obviously staged. Looking at the video, there are no pieces of tread coming off. The film clips are short. This is what causes most of the damage. Yet, still framing the tire is blurry and, for me, covered with adverts. However, it appears there is no tread on the blown tire. So, is the ad leaving an important part out?
PenJoe is offline   Reply With Quote
Old 01-20-2023, 08:28 AM   #16
If those prices are correct I would have to say what a joke . One could do better themselves for less then 1/5 the cost they show
MR.M is offline   Reply With Quote
Old 01-20-2023, 10:46 AM   #17
Tires barely clear the underneath of the slide. The design of these would have them moving up and down with the axles. Don't think there is adequate room underneath for clearance between them and the tire, and them and the slide. I know some may have more clearance, but mine certainly does not. Also wouldn't clear the slide support mechanism/ I'll stick with TitanMike's plan. Nice try though.
2003 Duramax
2017 Crusader 315
2016 Boston Whaler Montauk 150
Former Montana owner
Colorado Cruiser, Over the Pass and Down the Hill
Comanchecreek is offline   Reply With Quote
Old 01-20-2023, 11:08 AM   #18
Commercial Member
[IMG][/IMG]
Probably good for the water but doubt that a tread flaling would be stopped.
.Write a blog on RV tire application RV Tire Safety. 50+ years experience as tire design & forensic engineer. My RV Freelander 23QB on Chevy 4500 chassis. Giving seminars on RV Tire applications (not selling)@ FMCA Conventions. Aug 14-17 Redmond, OR
Tireman9 is offline   Reply With Quote
Old 01-20-2023, 11:22 AM   #19
Commercial Member
I saw this. I understand the unit will fit some RV trailers but not all. Looks substantial enough plate steel.
I am looking for videos on Youtube as I can't post here.
Old 01-20-2023, 12:47 PM   #20
suggestion about TPMS systems. Check the response time to display a pressure change. Some are REALLY slow and won't give you immediate warning of a blow out. That is critical to getting pulled over before too much damage occurs.
dedobias is offline   Reply With Quote
tire
