Old 12-24-2018, 09:28 AM   #1
Tire load ratings
Hi all. I have a 2015 Wildwood 32bhds. My tires were manufactured in 2014 and I am thinking it is time to replace them. I have noticed however that the factory tires appear to be under the gvwr. The factory tires are rated for 2,540lbs x 4 = 10,160lbs. My trailer dry weight per the sticker is 7,707 and max cargo is 3,184 for a total of 10,891lbs. This appears to leave the tire capacity short by 731lbs.
While I do not think we load the camper with 3,000lbs I still find this bothersome. Anyone else notice this with their rigs?
I am thinking I will look for a higher load capacity replacement.
e16wtd is offline   Reply With Quote
Old 12-24-2018, 09:52 AM   #2
About 900 pounds of that dry weight is on the hitch which will need to be deducted or added to your tire load calcs depending on how you look at it. The original tires appear to be properly rated. Good idea to make that tire change now.
2019 Rockwood 2902WS
2019 Ford F250 4X4 CCSB 6.2/4.30
Equalizer E2 with single old-school friction sway control.
woo10-210 is offline   Reply With Quote
Old 12-24-2018, 10:15 AM   #3
Fulltime family RVer
As woo10-210 mentioned, a portion of that weight is carried by the truck (tongue/pin weight). The axles/tires carry a portion of the trailer's total weight.
However if you can find a tire in a higher load range for a higher safety margin, that's usually a good thing to do.
Old 12-24-2018, 10:19 AM   #4
Completely forgot the hitch load. Well that is embarrassing.
Old 12-24-2018, 10:26 AM   #5
Don't be embarrassed! We get that question fairly regularly.
Old 12-24-2018, 10:30 AM   #6
Easy mistake. Just shows we're humans. Let us know what tire size, rating, and brand you decide to use.
Old 12-26-2018, 08:50 AM   #7
Keep forgetting about it and get tires to cover the full weight plus 20% . that Truck carries the weight argument is a bunch of C . it does when sitting still but once you head down the road hitting bumbs and dips there are times when the full weight of TT is on the TT tires Plus more when you consider extra inertia caused by bumps and dips in the road
MR.M is offline   Reply With Quote
tire
