Old 05-10-2021, 07:27 PM   #1
Tire pressure
Do any of you out there put a few extra pounds of air pressure; above the normal pressure; in your back tires when you are towing ?
Mountaineer1954 is offline   Reply With Quote
Old 05-10-2021, 07:40 PM   #2
Chief T's Avatar
I do, I air up to 45 psi on my BFG KO2 LRE tires. Firm enough to help, but not too rough a ride.
2012 GMC Sierra 1500 SLT Z71 6.2l aka "Luci"
2020 Grand Design Imagine XLS 22 MLE aka "Desi"
Past: 2017 Prime Time Tracer Air 206
Days camped 2018: 15
Days camped 2019: 17
Days camped 2020: 18
Chief T is offline   Reply With Quote
Old 05-10-2021, 08:03 PM   #3
Old 05-10-2021, 08:13 PM   #4
I run 36 PSI cold in my Durango. When hooked up to the trailer my TPMS shows they rise to 44 PSI on the road. Door sticker calls for 33 PSI.
NavyLCDR is offline   Reply With Quote
Old 05-10-2021, 08:24 PM   #5
The max rating is when cold. The tires can handle then hot psi.
phipps33 is offline   Reply With Quote
Old 05-10-2021, 08:31 PM   #6
You are correct, I edited my post.
Old 05-10-2021, 11:41 PM   #7
One truck calls for 35 psi and the other 32 psi. That's what I always run them at. I see no reason to up the psi when I'm within all the weight limits
2019 Silverado LTZ 1500 6.2L 10 Speed 3.42 Max Trailering Package
2018 Freedom Express 192RBS
2016 Silverado LTZ 1500 5.3L 6 Speed 3.42
2015 Jeep Wrangler Unlimited Rubicon 3.6L 4.10
2020 KZ 130RBSE
AlaskaErik is offline   Reply With Quote
Old 05-11-2021, 04:27 PM   #8
I typically go a few PSI (usually 3, max 5) over placard in all 4 tires (and the trailer) when we are changing altitude. If we are going up, it gets considerably cooler and we lose pressure. If we are going east, the extra air compensates for the higher ambient pressure. Since we are pretty close to payload with the tongue weight added, I want to make sure we stay at or above the placard, regardless of outside temp or altitude.
This has never created any issues, or uneven wear across the tire tread. I air the tires up the morning we are departing here from Colorado Springs, and just do a back of the hand temp check of the tires and bearings when we stop for fuel or food. I don't check pressures on the road unless something happened.
Fred W
2019 Flagstaff T21TBHW A-frame with 2018 OEM Castle Rocks
last trip - Trinidad Lake SP, CO
next trip - Indianapolis
Old 05-12-2021, 09:07 AM   #9
Lins's Avatar
Voice of reason right there.
I base my PSI off scale weights and a load and inflation table. Good traction, tire wear - and safety. A chalk test can also work in lieu of a scale.
2007 Rockwood 2701SS
1953 GMC 9314
1982 GoldWing Interstate
Lins is offline   Reply With Quote
pressure, tire
