Old 01-13-2019, 05:23 PM   #21
https://www.goodyearrvtires.com/pdfs...care-guide.pdf
Page 13 and 14
Regarding dressings:
Goodyear RV tires do not need dressings, appearance products or covers to help protect them. In fact, using
products that contain alcohol, petroleum or silicone may cause your Goodyear RV tires to deteriorate and crack.
Clean your tires whenever you wash your RV. You can wash your tires with the same products you use to wash
your RV – a soft brush and mild soap
Armour All contains 5% mineral oil according to its MSDS. It's the LAST thing you want to put on your tires.
babock is offline   Reply With Quote
Old 01-13-2019, 05:47 PM   #22
madatme's Avatar
well i spray that tire shine stuff all over the tire and wheel if its a aluminum wheel to help keep the corrosion at bay and keeps my tires nice clean shiny looking, kinda like spiffing up the brand new corvette, weather that helps or not beats me
madatme is offline   Reply With Quote
Old 01-13-2019, 09:38 PM   #23
Grapehound's Avatar
Originally Posted by jtesta1 View Post
I put barbecue sauce on my tires if my trailer is to sit a while. I figured that the barbecue sauce keeps my chicken from drying out on the grill . It's should do the same for my tires sitting in the sun and heat.
I use Brylcreem on my tires. I had some left over from when I was young and had hair.
2014 Rockwood Signature 8282 Ultra-Lite
2008 RAM 3500 HD DRW Laramie Megacab
6.7 Cummins Turbo Diesel
Grapehound is offline   Reply With Quote
Old 01-14-2019, 06:49 AM   #24
DouglasReid's Avatar
When it gets hot I bet you have an uncontrollable urge to gnaw on the rubber then
2008 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
DouglasReid is offline   Reply With Quote
Old 01-14-2019, 06:52 AM   #25
Whatever blocks the sun and its UV rays from getting to the rubber is a good idea. 303 Protectant is what I put on all the rubber outside on our camper. Ive seen cloth wheel covers and even a piece of plywood tied on so it cna't blow aaway.
Like I said, anything to keep the sun off of the rubber.
Dong' forget slide out seals, etc when you are putting the 303 on, they need it too
Old 01-15-2019, 11:19 PM   #26
madatme's Avatar
thats nasty
Old 01-21-2019, 09:13 PM   #27
Jacks?
Sun covers here in Florida plus jack stands under the axles to take the load off the tires. Avoids the thump thump of flat spots from long storage. Canít be good for the tire to not be round.
Papadave is offline   Reply With Quote
Old 01-21-2019, 09:24 PM   #28
Coach
Flat spots are a remnant from the bias ply tire days. Not nearly as common with radials.
Cut it 3 times and it's still too short...
2017 Sandpiper 381RBOK
2006 Ram 3500 Cummins Dually
valleyduo is offline   Reply With Quote
Old 01-21-2019, 09:49 PM   #29
Commercial Member
Here is the answer from a Tire Engineer.
RV Tire Safety: Tire Covers - Do they do any good?
I have seen tires that were destroied by some spray or wipe on shine stuff.
While UV and ozone are bad for tires HEAT is the killer.
White covers are the best way to go IMO.
If you are only driving 60 miles a year you should probably sell your new tires and buy some used tires. Be sure to have enough inflation to support 115% of the measured tire load.
.Write a blog on RV tire application RV Tire Safety. 40 years experience as tire design engineer. Freelander 23QB on Chevy chassis is my RV. Giving seminars on RV Tire applications (not selling)@ FMCA Conventions. Next in Mar 2021 in Perry, GA
Tireman9 is offline   Reply With Quote
Old 01-21-2019, 09:58 PM   #30
I stretch 30 gallon plastic trash bags over our RV tires when storing it. They have to be stretched a little bit to put them on and they won't blow away.
Bill J., Lexington, KY.
whjco is offline   Reply With Quote
Old 01-21-2019, 10:02 PM   #31
Commercial Member
If the bags are black and tight you are storing your tires in an oven. Really NOT GOOD.
Old 01-21-2019, 11:04 PM   #32
I spend six months in the winter at Isla Blanca just across the bridge from you so Hello. My 2015 320RS is facing North and with the slides out I think the tires on the East side only get a couple of hours of sun first thing in the morning and on the West side a couple of hours in the evening. I don't do anything to protect them. My original China bombs lasted four years with no problems except one flat by nail and one flat by a leaking tire stem. Both were caught by my TPMS before going completely flat.
bobneal69 is offline   Reply With Quote
Old 01-22-2019, 12:13 AM   #33
They're silver bags.
Old 01-22-2019, 09:03 AM   #34
Going Solo
tjwdj's Avatar
What is 303?
Can I ask what 303 is?? A spray on? Automotive product? Thx!
Originally Posted by Fifth Wheelers View Post
We use 303 and tire covers, no problems. Check tire pressure once a month while we are parked.
tjwdj is offline   Reply With Quote
Old 01-22-2019, 09:13 AM   #35
Google is your friend...
303ģ AEROSPACE PROTECTANT
Days Camped: '17=30 '18=51 '19=58 '20=98
Old 01-22-2019, 02:46 PM   #36
Originally Posted by Fluffywhitedogs View Post
RobinDella is offline   Reply With Quote
Old 01-22-2019, 02:55 PM   #37
https://www.amazon.com/303-30382-Pro...-2-spons&psc=1
Old 01-22-2019, 03:25 PM   #38
GOODBYE SUIT - HELLO RV!!
Originally Posted by jerryadair View Post
We left our RV at a storage place 30 minutes away last spring. This fall we moved it the 30 miles back to our spot in Port Isabel Texas, just off the Gulf of Texas. We don't intend to move our RV again until April, likely back to the storage place.Thanks in advance for your thoughts!
The hot Florida sun bakes everything. We cover our tires with thick but breathable canvas covers. They stay on fine, even in wind. To keep them on in heavy weather, I tie the sides together from behind the wheels.
LOVE CAMP LIFE... 35+ years camping and still going....
2019 Rockwood 2104s w/Equalizer 4-point WDH
2017 Ford Expedition 4WD 3.5L TwinTurbo V6 w/Heavy Duty Tow Pkg (Artemis)
2017 Ford Mustang GT Premium California Special Convertible (The Beast)
2006 Ford Mustang 3.0 V6 Convertible (Lil' Blue)
HappyCamper1962 is offline   Reply With Quote
tire
