Old 04-15-2024, 10:13 PM   #1
Tire Storage Surface
We have a 2020 2511S Mini Lite with 4 two year old Goodyear Endurance 205/75R14 tires. They are mounted on Dexter dual axles with a TPS system and properly maintained tire pressure. Great shape for the miles of adventures they have given us.
Recently purchased a home in southern Delaware and cannot at this time pour a concrete pad for long term storage.
So I cleared 5 30'-40' trees, cut back brush and removed mounds of leaves to create a semi level 12'X30' parking area for our TT. I then laid down 3/4" gravel 6' long, 3' wide and 2"-3" deep for the tires to rest on.. See attached photo: Click image for larger version
This is due to the sandy soil and not wanting our TT to sink during a rain storm. My question to you all is:
Should I put something between the tires and gravel?
Horse blanket? (read that one somewhere on this forum)
2"X12" wood planks?
Old rugs?
Rubber mats?
We have been to a few campsites that were gravel but not for extended periods of time.
Any and all suggestions and comments will be appreciated.
Thank you in advance for your thoughts and safe travels.
2020 Rockwood 2511S MiniLite
2018 RAM 2500 Crew Cab 6' bed 4X4 6.7L Cummins Diesel Turbo 6 Speed Rear Posi Traction
'We may never pass this way again'
2021 Days Camping 184
2022 Days Camping 126
2023 Days Camping 128
TwoKozy is offline   Reply With Quote
Old 04-16-2024, 06:17 AM   #2
Oaklevel's Avatar
Many will disagree with me but I own 6 trailers including the camper and park them on treated 2 x 12s, gravel, and dirt. I see little to no difference in the aging of the tires.
I get at least 5 years from each method and have not had tire issues because of any method of storage . Over 40 years I never have had the luxury of storing a trailer on concrete.
On a side note I have found different areas call gravel different things. Here I now mostly use pug mill or crusher run, 57's are cheaper by volume but don't pack.
Don't stress of your choice.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Old 04-16-2024, 06:43 AM   #3
Yep, you have to figure that is no different than going from campground to campground with different sites.
I think the biggest detriment is sitting and the tires not rotating. I am at my summer site now. Every 14-17 days I need to dump so my tires get rotated even if it is less then 1/3 mile round trip. Good/bad, I don't know but they are rotating once in a while.
Grass site so I switch sites so it can be mowed too. Some of the folks stay put and hand mow around their campers.
2022 Rockwood 2511S
2018 F150 3.5 Crew Cab 4x4
Max Tow Package 1855 Lbs Payload
Husky CenterLine WDH
GolfingDave is offline   Reply With Quote
Old 04-16-2024, 07:01 AM   #4
So I cleared 5 30'-40' trees, cut back brush and removed mounds of leaves to create a semi level 12'X30' parking area for our TT. I then laid down 3/4" gravel 6' long, 3' wide and 2"-3" deep for the tires to rest on.. See attached photo: Attachment 298739
2"X12" wood planks?
Old rugs?
Rubber mats?
We park ours on 5/4 PT decking. Just wide enough for the tires and spreads the load
MGD1961 is offline   Reply With Quote
Old 04-16-2024, 03:08 PM   #5
Willhound's Avatar
As long as not sinking into the ground, I don't think the surface matters much. Just my opinion. I think the sun does more damage than anything. And keeping proper pressure and moving them once in a while might prevent a flat spot.
2018 Cherokee 39RL
Willhound is offline   Reply With Quote
Old 04-16-2024, 04:05 PM   #6
RedLdr1's Avatar
Gravel allows for great drainage and airflow around the tires. I'd stop with what you've done.
Wayne
2024 Sunseeker 2150SLEF / 2025 Ford E-350
RedLdr1 is offline   Reply With Quote
Old 04-17-2024, 05:27 AM   #7
I'm no rubber chemist but would agree that sun, inappropriate pressure and lack of movement, likely do more damage than the parking pad material.
One thing you might want to be planning on, is upgrading your parking spot as you can.
That looks like a fairly humid spot. More air flow the better and some sort of covering on the ground, even if just starting with a full gravel pad. I've found that long term parking of any vehicle on grass / dirt, to really accelerate deterioration.
2024 Surveyor 252RBLE
2023 F150 Powerboost 7.2KW 4x4 1658PL with a WeighSafe WDH
DJ252 is online now   Reply With Quote
Old 04-17-2024, 07:45 AM   #8
X2
As long as the water drains from the area and the tires are not sitting in water, they will do just fine on the gravel.
Like Oaklevel, I've got multiple trailers sitting on all kinds of surfaces and none exhibit tire issues but they are all on well drained areas and not sitting in mud or water.
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=90
storage, tire
