Old 10-03-2017, 12:43 PM   #1
Tire Torque
I changed a tire on my TT. I torqued to 120 ft lbs. Looking here I see it should be to 100. Would I do any damage if I leave it be or should I drop down to 100?
Thank you.
Dee and Chuck (Both retired),Maggie (Boston Terrier, Rip) and Duffy (Westie, Rip)
2015 Ford F150 Ecoboost
2017 Flagstaff 26RLWS (5/2016-Present)
Grandchildren fill the space in your heart you never knew was empty. Nick 25 y/o and Leif 6 1/2 yrs.
cruisegrandma is offline   Reply With Quote
Old 10-03-2017, 12:46 PM   #2
Re-torque it to 100.
babock is offline   Reply With Quote
Old 10-03-2017, 01:04 PM   #3
Restcure's Avatar
Agreed, and while you're at it...
When I was in my teens my Dad taught me how to torque wheel lug nuts properly. He learned himself at a young age from a heavy equipment mechanic, who explained that fasteners torqued in this way can be relied upon not to loosen... especially useful when those fasteners are difficult to access. The method is a combination of pattern and gradual application of torque. I've used it for since the first time I put a wheel on a car and it has served me well.
The torque pattern is pretty simple:
In combination with the pattern is the gradual application of torque. One third of the spec for all lugs, then two thirds, then full torque.
So when I'm installing a trailer tire, here's my procedure:
  1. Place the tire on the hub - I usually do this from a sitting position, balancing the tire on my feet.
  2. Finger-tighten the lug nuts while shifting the tire with my feet - this helps to ensure that the cones of the lug nuts centre the wheels on the lugs. I repeat this, moving from one nut to another, until all are finger-tight. At this point I'll snug them up a bit more with breaker bar and socket, but not much.
  3. Lower the trailer until all the weight is on the tires.
  4. Set the torque wrench to one third of the spec. In my case, 33 lb-ft (the spec is 100 lb-ft) and torque the lug nuts in the pattern shown above.
  5. Set the torque wrench to two thirds (66 ft-lb) and torque the nuts in the same pattern.
  6. Set the torque wrench to the full spec (100 ft-lb) and torque in the pattern once more.
Nowadays it's common for car and RV repair shops to warn you to check lug nut torque after driving for 100 km. With this method, that's not necessary; I've done spot checks and have never found a loose lug nut. And when I get a vehicle back from such a shop, I always loosen and re-torque the wheels this way.
2012 Rockwood Ultra-Lite 2701SS, Goodyear Endurance LRD, ProPride 3P 1400 hitch
2013 F-150 FX4 7700# GVWR SuperCrew 3.5L EcoBoost 157" WB Max Tow 3.73:1
John, Dawn and Emily... and Bella the camping kitty
visit our website at www.restcure.ca
Restcure is offline   Reply With Quote
Old 10-03-2017, 02:14 PM   #4
Thanks to you both. Restcure -- That's the method I use also except I did 40, 80, 120 by mistake.
Old 10-03-2017, 02:35 PM   #5
Restcure's Avatar
Awesome! You just need to adjust the numbers!
Old 10-03-2017, 03:36 PM   #6
A32Deuce's Avatar
Half inch studs, in my experience are torqued to 100 foot pounds in 3 increments.
A32Deuce is offline   Reply With Quote
tire
