Old 04-20-2024, 04:54 PM   #1
Ontario camper's Avatar
Tires ?
I’m sure this has been covered somewhere but I’ll ask anyway….
I have a 2024 GMC AT4 3.0L diesel half ton and pulling a 2023 Rockwood 2614BS
Total trailer weight is 8040lbs my truck is good to pull 9100lbs so no issues there and I use a blue ox sway pro WD hitch I keep my chains at 10 I have Goodyear wrangler duratrac LT265/60R20 c rating (6 ply) tires on this truck never had these tires before
looking for advice or if anyone else is pulling similar truck and trailer to compare thoughts
Just got back from Myrtle beach from Ontario Canada and truck worked great although had some sway here and there when passing or getting passed by big rigs and was pretty windy in some spots ran about 65mph avg and I was probably a little over on hitch weight by maybe 150lbs (did a cat scale weight)
Wondering what people are running if 6 ply is good or go to 8-10 ply ? I know more ply means more noise
Thanks !
ID:	298885   Click image for larger version
Ontario camper is offline   Reply With Quote
Old 04-20-2024, 06:02 PM   #2
bikendan's Avatar
Moved thread from the Running Gear/ Axles/ Brakes/ Frames and Tires sub-forum to the Towing, Tow Vehicles and Hitches sub-forum since the OP's questions are for Tow vehicle tires, not trailer tires.
Old 04-20-2024, 06:14 PM   #3
acadianbob's Avatar
IMO LR E on a half ton pickup is overkill and will brutally affect your ride. LR C is plenty.
2021 F350 Lariat 7.3 4X4 w 4.30s, 2018 Wildcat 29RLX
Red Green coffee mugs
Old 04-20-2024, 08:08 PM   #4
bikendan's Avatar
I put Load Range D Michelins on my F150 and the ride was very comfortable.
Old 04-20-2024, 10:39 PM   #5
I'm running Load D Range Goodyears. Ride is quiet and comfortable. Better ride than our Accura.
2021 2205S Rockwood Minilite
2019 F 150 Lariat 3.5 Eco Fx4 Max Tow
Equal-i-zer WDH, 1809 lb payload
flyflotrtim is offline   Reply With Quote
Old 04-21-2024, 05:30 AM   #6
BigH's Avatar
First off...I'm with the load range D group if you are going to be spending significant time towing with your half ton. D's will reduce some of the body roll attributed to the tires if you're an aggressive driver when not towing.
Now about your current tires...I've swapped between summer and winter tires on my last three trucks. My winter tires were the same Duratrac tires you have. (and they are awesome for winter weather use but noisy).
Early one year I had to the move the camper and I used my winter Duratrac tires. I instantly noticed a squirm or wiggle. The truck just didn't feel as planted. It wasn't bad but that effect may be more noticeable with less truck/tire...I had a 2500 series truck at that time. There is no question it was the tires. I think it had to do with the tall tread blocks and large gaps between the lugs allowed the tires to 'shift' around a little.
24 Ram 3500 CC/SRW/LB/50 gal tank/CTD
2024 XLR 31A LE
BigH is offline   Reply With Quote
tire, tires
