I have seen other pictures/discussions of failures like this. There's at least one YouTube video from a guy that had it happen in Alaska.
I have to wonder how many of these failures happen after negotiating a significant dip in the road? If the trailer is still going downhill, while the the tow vehicle trying to go uphill, and the weight distributing bars are fighting the ability of the hitch to pivot - at some point something is going to break.
Without the weight distribution bars, the hitch ball is free to pivot up and down and could tolerate a significant break angle. But once those bars are connected you would be limited by the amount they can bend. At some point they are going to cause the hitch ball pivot to become rigid. Now the ball is lifting on the front of the tongue, and the bars are pulling down on the A-frame, creating a fulcrum. Something is going to break - either the bars, the chains, the hitch head, or the trailer frame.
That's really the biggest downside of weight distribution hitches - the tool that makes it where you can safely pull more weight than you would be able to otherwise, by limiting the pivot range of the ball connection, also limits the terrain that you can traverse because it limits the pivot range of the ball connection.
-Qwkynuf
2003 F150 Supercab 4x4, tow pkg, 3.55 gears
2020 Flagstaff Micro Lite 21DS
