Old 04-27-2022, 12:54 PM   #1
hkreck's Avatar
Trailer lugnuts
I got some new lug nuts to replace the cheap ones that came on my trailer. The manufacture lug nut were marked as 1/2-20, which I understand is and normal lug nut for most trailers. When I got the new lug nuts they were marked as 1/2-20/T. Can someone enlighten me as to what the T means and if these lug nuts will work on my trailer? Thanks.
Henry & Tena
hkreck is offline   Reply With Quote
Old 04-27-2022, 03:21 PM   #2
Boborc's Avatar
Probably stands for tapered. There are like 3 or 4 different type of seats on lug nut's
2021 Apex 253RLS
2015 GMC Canyon
Boborc is offline   Reply With Quote
Old 04-27-2022, 03:22 PM   #3
Boborc's Avatar
https://www.discounttiredirect.com/learn/lug-nuts
2021 Apex 253RLS
2015 GMC Canyon
Old 04-27-2022, 04:16 PM   #4
D W
D W's Avatar
Steel wheels typically use a 60° tapered lug nut. Alloy wheels use a special clamping lug nut, and it can vary according to manufacturer. They're designed to fasten the wheel at a lower torque to preclude cracking the wheel mounting flange.
2016 Salem 27RKSS
D W is offline   Reply With Quote
Old 04-27-2022, 05:02 PM   #5
hkreck's Avatar
Thanks for the replies, everything I've found and been told so far indicates that the lug nuts I purchased will work on my trailer so I'll go with them and torque to the specs on the side of the trailer. Thanks again. Happy camping.
Henry & Tena
trailer
