03-29-2022, 05:15 PM
Trying to program internal TST sensors
I got my new to me 2020 25fks last year.
I didn't get the TST monitor it was supposed to have (don't' ask) so I bought the color one late last year.
I know that the sensors are supposed to be inside the rim, and I know I have them, as I had the sticker and I see the red light for the repeater under the frame on the tongue.
So today I tried to program the monitor, and 1st thing I noticed this thing is dim as hell outside. I was in the shade of the trailer too! Can't hardly see anything once I go into setup mode. Is this normal? I can't imagine seeing this while sitting on my dash.
The 2nd thing is it doesn't sense any sensors. I went around to all the tires, at all positions. I know they are supposed to be 180 deg from the valve stem.
Can't imagine they batteries would be dead in 2 years.
Any ideas before I call TST?
thanks
Rick
2020 Micro Lite 25FKS Theater Seating
03-30-2022, 07:34 PM
Can't really help you on programming, but do you think the TPMS sensors are on the opposite side of the rim/tire as the valve stem, or do you think they are on the inside end of the valve stem. The only place I have ever seen an internal sensor mounted is on the end of a valve stem, either inside or outside, but never on the opposite side of the wheel/tire.
I would suggest you remove a wheel, take it to a tire shop, have them dismount the tire and see if there is a TPMS sensor installed. There might also be a part # on it that would tell you what system it is compatible with.
03-30-2022, 07:36 PM
I would suggest you remove a wheel, take it to a tire shop, have them dismount the tire and see if the sensor is present or not.
03-31-2022, 08:25 AM
Stupid question but did you charge the TST Monitor? Ours is bright enough to read in full sun.
03-31-2022, 09:13 AM
thanks for the replies everyone.
I got it working last night.Not sure what I was doing wrong,but it decided to start working.
Regarding the monitor, yes, it is fully charged.
I am sending an email to their support with pictures, that show you can't see anything.
Oh, and on another point, back when I bought this, I was asking about how to check if you had the sensors and said something about the green valve stem caps, which I assumed meant I had sensors installed.
I got several responses on this forum saying that just meant I had the nitrogen in the tires. I accepted that. Yesterday when looking on the TST website, I found a page that tells you that a yellow or green valve stem cap means you have the internal sensors.
Just an fyi for someone who buys one of these used and is not sure.
thanks
03-31-2022, 11:30 AM
Glad to hear you got it working .
04-01-2022, 12:43 PM
thanks
Green valve stems caps has 100% absolutely nothing to do with TPMS. My trailer came from the factory with green valve stem caps and had no TPMS. Green valve stem caps are supposed to indicate Nitrogen. That can't be trusted though, in reality green caps mean 100% absolutely NOTHING.
Hundreds of thousands of RVs come from the factory with green stem caps and no TPMS sensors.
04-01-2022, 03:35 PM
My Montana arrived from the factory with sensors installed, yellow caps on all 5 tires. The monitor and instructions in a drawer. Took about 15 minutes to set all 5 as I don’t crawl around the spare very well at 74.
2022 Montana 3855 BR
2019 F350 6.7 4X4 LB Dually
Edgewater 205 EX 150 Yamaha
