Old 09-25-2018, 07:17 AM   #1
TST 507
What pressure do you go by when checking tire pressure The TST 507 or a pressure gauge ? I always get 2 different readings.
geegoat is offline   Reply With Quote
Old 09-25-2018, 07:30 AM   #2
Flybob's Avatar
I would go by the readings of a good tire pressure gauge. I consider the TPMS system as an indicator of a problem and warning system and not an accurate tire pressure gauge although my readings are close.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 09-25-2018, 10:51 AM   #3
Jim34RL's Avatar
I use a digital tire pressure gage rated to 150 PSI, I never trust a TPMS systems at all. I won't install them on my trailer tires, just another expense that is not required.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 135K+miles
Old 09-25-2018, 11:00 AM   #4
All reports I've read in multiple forums say most TPMS pressures are usually a couple of pounds different than an accurate pressure gauge.
As mentioned, I check mine at the beginning of the season with a known good gauge and then use whatever my TPMS pressures are as a baseline after that. In my case, 70 psi with a gauge is 69 psi with the TPMS. If I back up the truck to hitch up and all are blinking at or near 69 psi, I'm good to go. Ambient temperature/sun on a tire(s) can make the pressure fluctuate a pound or two. No big deal.
Days Camped: '17=30 '18=51 '19=58 '20=98
Old 09-25-2018, 11:01 AM   #5
Lots of things are 'not required'.
Peace of mind is priceless.
Old 09-25-2018, 11:02 AM   #6
Georgia Rally Coordinator
aceinspp's Avatar
Might change your mind when you have a blowout on your camper and do damage to camper. Later RJD
2020 Shasta Phoenix SPF 27RKSS
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
Days camped 2020 46
Old 10-09-2018, 06:28 PM   #7
Would it not rely on the accuracy if the guage? I have seen different guages have a tighter window on accuracy and some with higher amounts +/-
OKI Marine is offline   Reply With Quote
Old 10-09-2018, 06:33 PM   #8
Do you like the TST 507 ? I am very interested in purchasing one. I have had some blowouts with one doing iver $3700 damage to the camper. The sidewall blew out and the tread whipped around and tore.up the bottom of the slide, wheel skirt and took out the back tank and lines. I would like to get a little advance warning instead of looking in the mirror and see rubber and what not flying and cars driving down into the median.
Old 10-09-2018, 06:36 PM   #9
Mr. Dan's Avatar
Many of us like the TST 507 system. You can do a Search and find all kinds of testimonials.
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 = 111/'19 = 86/'20 = 94; booked = 14
Old 10-09-2018, 06:36 PM   #10
Multi-Slacker
TST 507 is as good as they come and the support is the best
2017 Forest River Sonoma 280RKS
2018 Silverado 2500 HD 6.0L, 4:10 rear
CurtPutnam is offline   Reply With Quote
Old 10-09-2018, 06:42 PM   #11
rsdata's Avatar
I believe YOU hold a minority opinion... at least this is the first time I have read that someone specifically said they will not use a TPMS on their trailer.
To each their own... good luck!
geegoat...
I find my flo-thru sensors are 2-3# lower then my gauge... all four of them read that low when I use my digital gauge, so I suppose my digital might be off, but all close enough for me.
"Freedom is never more than one generation away from extinction. " - Ronald Reagan
ďToo much of anything is bad, but too much good whiskey is barely enough.Ē Ė Mark Twain
2014 Shamrock 183
Old 10-09-2018, 06:52 PM   #12
I check my tires at the beginning of a new camping year with a digital gauge and then check what the pressure says on my TST 507. Thatís the last time I check the tires with a gauge for the rest of the camping season. I trust the TST 507 system, it hasnít failed me yet. If you are looking for a good TPMS you canít go wrong with the TST system
spock123 is offline   Reply With Quote
Old 10-09-2018, 08:41 PM   #13
Do you inflate your tires to max psi? I had heard that heat increases the psi. I have been inflating mine about 4-5 psi under max
Old 10-09-2018, 08:48 PM   #14
On my trailer tires which is G614 the pressure on the yellow place card is 110psi. I inflate them to 105psi. On my truck I run what door sticker says, 60psi front tires, 80psi rear tires
