05-07-2020, 04:55 PM
Camp-N-Nut
TST 507
Where is the best place to buy a TST 507 tire monitoring system with a color monitor? Also do I need a signal booster? I tow a 39’ fifth wheel. Are the sensors that mount inside the tire/valve stem better?
2015 Cedar Creek 34 RLSA
2006 Dodge Laramie Dually Cummins
05-07-2020, 05:11 PM
I can't tell you where to buy a TST-507 tpms but would suggest you just google it and see what you can find. As far as the tire sensors keep in mind the batteries in them last about 2 years. The valve stem caps and flow through sensors the batteries can be replaced but the internal sensors batteries are not replaceable. Meaning you will be buying replacement sensors every couple of years and I think they cost some where in the neighborhood of 80 bucks per plus the cost to have the tires broke down to install them. I have a camper with dual axles and need to replace the batteries on my flow through sensors this year and including 4 batteries and the replacement battery cover seals I have about 30 bucks total in it. Just my thoughts on this this matter, good luck.
05-07-2020, 05:34 PM
I have the type that mount on the valve stem; for ease of changing batteries. That approach does require the installation of metal valve stems.
We have a 33' fifth wheel; and no booster is required.
2021 F350 Lariat 7.3 4X4 w 4.30s, 2018 Wildcat 29RLX
Red Green coffee mugs
05-07-2020, 05:46 PM
Next time, buy o-rings and the batteries online. Way cheaper. I bought a big bag of o-rings that will last me a long time.
https://www.ebay.com/itm/50Pcs-Black...72.m2749.l2649
EDIT: just realized you have the flow through sensors. I have the screw on ones. Not sure they are the same size.
05-07-2020, 06:25 PM
Multi-Slacker
Originally Posted by babock
Thanks for the tip on the O-rings. Got a similar good source for cap sensor batteries?
Safe Travels
05-07-2020, 09:00 PM
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
05-08-2020, 10:02 AM
TST 507
Georgetown VE 34.1 DS
Favorite Drink: Buffalo Trace & Good craft beers with Great Cigars !!
05-08-2020, 03:04 PM
Camp-N-Nut
Thank you everyone. I just have to decide if I want the flow thru or regular caps.
05-08-2020, 03:19 PM
My 2 cents- I would buy the unit first without the repeater and see how it works. No need to spend extra $$$ if not needed.
Tweety’s has good prices also.
Just glad to get away
05-08-2020, 03:30 PM
Personally, I would just get the regular caps and take the security device off. They weigh less and have less leakage issues.
05-14-2020, 08:49 AM
I have the flow through caps, if they fail, or I were to do it again I would buy the cap stile. Every time I have tried to put air in a tire with them on it gives a weird reading till I remove / replace then they go back to normal. Kinda defeats the point. Wont travel without them, have saved me money twice.
Dale & Karen
2015 Lacrosse 311RLS
2006 F-250 The 06-6.0
05-14-2020, 05:24 PM
Mine came with the repeater and yes it was needed.
2007 Rockwood 2701SS
1953 GMC 9314
1982 GoldWing Interstate
05-14-2020, 05:43 PM
Señor Member
https://tsttruck.com/
Good people.
2017 Forester
3051S "Bluga"
05-14-2020, 06:17 PM
I purchased ours from tsttruck.com as well. I have the internal mounted sensor for about 3 years now. Battery life said 5-7 years.
05-29-2020, 02:53 PM
Tweety's.
No security cap, no o ring, and remove the batteries each winter.
24/7/365 on the TV also.
My most favorite people are Navy Corpsmen and Marine medivac helicopter pilots and crew - MEJ 1968
05-29-2020, 07:14 PM
Why no O-ring? They are a few pennies.
Originally Posted by mjacxx
Tweety's.
