I have not seen this model used on RVs what I have seen is the valve mounted flow thru or none flow thru very easy to change the battery on the flow thru. The plus side of the flow thru is if you are in storage you remove the sender from the valve stem and it stops transmitting and saves the battery (according to TST)
Retired Navy
2016 Flagstaff 26 FKWS
