Today I installed the second Endurance.
Hadn’t used a tire machine for 30 years or more and couldn’t figure out getting the second bead on the rim ;(
My SIL saw the tire on the machine & mounted that one for me.
So I mounted the first tire on the TT, jacked it up & removed all the blocking.
Then I did the second side. YEA! I figured out getting the other tire bead on.
When releasing the jack pressure lowering the trailer, the TT moved a bit. The tongue jack shifted total near 2”.
Went +1 upsize. 215/75R14. Minimal increase in capacity, but gained near 1/2” in trailer clearance, better tire, & a bit more road contact patch helping stability.
2019 Cherokee Wolf Pup 16BHS flipped axle, 5K springs, 400AH LiFePO4, 3K inverter, 400 watts CIGS solar
2019 Ford F-150 S-Crew 5.5 bed V8 w/tow package, ITBC, Tow Mirrors, 3.55, SumoSprings, 7000# GVWR, 1990#CC
Husky Centerline TS WDH 400-600# spring bars
