Old 09-20-2021, 07:48 PM   #1
Under side water proofing
During my trip to Ocean lakes the house wrap looking stuff tore loose from the underside of my camper.
I have put it back up the best I could and it looks like I will be traveling back home in the rain, one will I have much damage to the sub floor and wooden floor supports.
Two once it dries out can I put spray foam insulation, new house wrap and some other type of water proof material back in place.
Thanks in advance
2016 wildwood x-lite 241qbxl
being jurked down the road by the beast 2007 Dodge ram 2500
5.9 cummins g56 Trans southbend clutch and a smarty
railroaderone is offline   Reply With Quote
Old 09-21-2021, 09:05 AM   #2
SeaDog's Avatar
What area of the rig are you talking about that tore loose? I know you said underside does your rig not have coporlast installed on the underbelly. House wrap like material is usually found in the wheel wells and under the slide box. Unless you are in sever rain conditions I doubt that water would reach your flooring.
Retired Navy
2016 Flagstaff 26 FKWS
SeaDog is online now   Reply With Quote
Old 09-21-2021, 09:50 AM   #3
If wood gets wet and properly dried (heat and air movement so it doesnít mold) you shouldnít have a rot problem. Wood rots with moisture when itís left to stay wet for long periods of time. Removing and getting rid of fibreglass insulation is important.
Iím not so sure if I would use spray foam in some areas in the underbelly as I want to have access to plumbing and electrical if needing to deal with it. A friend had a situation similar to yours, when he put back the insulation he tucked it into plastic bags and sealed them to keep it dry down the road.
Rolland is offline   Reply With Quote
Old 09-21-2021, 10:34 AM   #4
There is no insulation on mine just the house wrap.
Old 09-22-2021, 07:57 AM   #5
Vince and Charlette's Avatar
I would highly recommend FlexSeal. It is a clear flexible spray-on sealant. I’ve even used it to seal around the chimney on the roof of my house. Lots of good reviews. It’s available at Lowes and Walmart.
2018 Berkshire 38A
Vince and Charlette is offline   Reply With Quote
Old 09-22-2021, 05:36 PM   #6
This must be a new camper. The manufacturers ran out of batt insulation and started using the vapor barrier insulation.
If it were me, I would put up fiberglass batt insulation, cover that with the "housewrap" material and then cover this with cloroplast plastic sheeting using lots of sheet metal screws and fender washers. Seal as appropriate to finish the project.
The Flex Seal might not be a bad idea on the underbelly before you begin insulation. Just don't cover wires, pipes, etc. as previously mentioned in reference to spray foam.
Good luck!
boogiejack75 is offline   Reply With Quote
roo, roof, water
