Old 09-04-2018, 07:25 PM   #1
Undercarrriage repair
Hi guys/gals.
After 14 years of hauling RVís Iíve had my first tire blow out. Right rear tire. Psi was 78 and went down normal roads Iíve been on multiple times. None the less a blow out. Fender etc thankfully was still intact.
Question I have is the mesh type material that is used in undercarriage , what is it and where can I get?
2011 wildcat 32qbt
James
Minty is offline   Reply With Quote
Old 09-04-2018, 09:23 PM   #2
Google black mesh tape which is what I used to repair slight damage to my RV from a tire blowout.
My last ST tire blowout was several years ago on a brand new tire about 20 minutes back from the tire store.
I now have light truck tires and tow worry free.
Ilovemywife is offline   Reply With Quote
Old 09-04-2018, 10:17 PM   #3
SailorSam20500's Avatar
I was at some seminar where they were talking about how often the source of a water leak is the wheel well area. I asked about coating the tire area with bed liner spray to waterproof it. Presenter thought it would be a good idea...
Maybe you can forgo the fiber stuff and just spray it.
Good luck.
Al
Save the Earth. Itís the only known planet with Beer.
There are times where my greatest accomplishment is keeping my mouth shut...
S.E. Mich. Flagstaff 26FKWS / 2019 F-150 3.5 EcoBoost SCrew Propride
SailorSam20500 is offline   Reply With Quote
Old 09-07-2018, 10:41 AM   #4
I will look into the tape.
As for the spray liner that would be nice too but with insulation there to keep cold out from under counter etc I need to add it back
So when I find the tape where can I find the material. I have about 3 sqft or more to cover.
Old 01-05-2019, 08:32 PM   #5
Novice
Undercarriage fabric repair
Hi Minty and Everyone,
It's good to find someone else with my problem.
While in heavy traffic, we were forced to run over a coil of cable in the road. Later, we discovered that the fabric underneath had been ripped to shreds.
(I didn't even know there was fabric under the RV.)
Our dealership wants about $500. to repair/replace this fabric. YIKES !
Does anyone have a good do it yourself method ?
I sincerely appreciate any and all ideas.
Thanks,
Cyn Cyn
Cyn Cyn & Don
Forest River, 2016 Salem 241QBXL
Lincoln Navigator
Dallas,Texas
cyn cyn is offline   Reply With Quote
Old 01-06-2019, 11:46 AM   #6
Iíve use this brand before. If you search for the scrim shield tape on Amazon there will be many choices
Surface Shields (BP4180 4" x 180' Scrim Shield Repair Tape https://www.amazon.com/dp/B002SSGAZG..._NbJmCb5QPK3RZ
The stuff is super sticky so you want to work with small pieces and overlap At the seam. they make a very good watertight seal
2016 RAM 3500 DRW 4x4 LB LoneStar Edition, w/Timbrens, Andersen Ultimate 2, Swift Hitch SH04 WiFi Backup/Rear View Camera
2018 Chaparral 360IBL w/Tireminder SMART TPMS, Furrion Wireless Observation System, Progressive EMS-HW50C
2006 RAM 3500 DRW LoneStar Edition
2011 Starcraft 392BHU w/Andersen No-Sway hitch
chaps2018 is offline   Reply With Quote
Old 01-06-2019, 11:59 AM   #7
rsdata's Avatar
depending on what the actual damage is... I look to Gorilla tape in 3 inch width... that is tough stuff with double the sticky side stuff...
then if the area is real large, get a cheap HFreight tarp and cut to size. Fasten it up there with staples or self-threading 1/2" SS screws. Then spray the penetrations with the rubberized undercoating stuff that comes in spray cans. Maybe spray some sticky stuff under the tarp before putting it up there.
I think you can get creative...
"Freedom is never more than one generation away from extinction. " - Ronald Reagan
ďToo much of anything is bad, but too much good whiskey is barely enough.Ē Ė Mark Twain
2014 Shamrock 183
repair
