Old 08-01-2020, 11:02 AM   #1
A2pfunk's Avatar
Uneven tire wear, how do I fix this can I adjust the alignment?
I have a 2015 Coachmen Catalina 273tbs. I have Goodyear endurance tires on all four wheels. This season I noticed that my front right tire is wearing unevenly. The outside of the tire is balding particularly fast. After our last 2300 mile trip, the outside of that tire is pretty much bald. The other wheels don't seem to be wearing quite like that. The back axle seems just fine. Do I need to adjust the alignment on this? And if so, how in the world do I do that? On another note, the Goodyear endurance tires are on national backorder and nearly impossible to find in my size. Click image for larger version
2015 Coachmen Catalina 273TBS pulled by a 2019 F150 Platinum.
A2pfunk is offline   Reply With Quote
Old 08-01-2020, 11:23 AM   #2
First pull the trailer forward in a straight line 10 feet to be sure your not getting any twisting from a turn. Get down behind the trailer like a golfer lining up a putt and see if the top of that wheel is tipped outwards compared to the other wheel and the other-side tires. We can give you a better guess once we know. You should jack that tire up and make sure there's no wobble from loose bearings too.
2019 F150 4X4 7050 GVWR 1903 payload
2018 Avenger 21RBS 7700 GVWR
Mike134 is offline   Reply With Quote
Old 08-01-2020, 11:25 AM   #3
Originally Posted by A2pfunk View Post
I have a 2015 Coachmen Catalina 273tbs. I have Goodyear endurance tires on all four wheels. This season I noticed that my front right tire is wearing unevenly. The outside of the tire is balding particularly fast. After our last 2300 mile trip, the outside of that tire is pretty much bald. The other wheels don't seem to be wearing quite like that. The back axle seems just fine. Do I need to adjust the alignment on this? And if so, how in the world do I do that? On another note, the Goodyear endurance tires are on national backorder and nearly impossible to find in my size. Attachment 235311
There's not much you yourself can do to adjust this unless you have both the equipment and training to deal with the axle itself. No adjustments built in.
It's hard to see in the picture but do you have conventional leaf spring suspension or torsion axles?
If conventional spring suspension, probably the best would be to replace the axle beam/tube itself. If you have a good jack and some jack stands along with the usual tools it's a fairly straight forward DIY project. A straight beam/tube axle can be bent to correct alignment angles by a knowledgeable and properly equipped shop but labor cost may meet or exceed the cost of a replacement axle.
If Torsion axles they too can be replaced by yourself, the axle is just a little larger with the swing arms on each end. Torsion axles can not be aligned by bending and should just be replaced (although I'm sure some have tried).
"A wise man can change his mind. A fool never will."
"Sometimes you're the dog, sometimes you're the tree"
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 08-01-2020, 11:48 AM   #4
Chris Pastuzyn's Avatar
Here's a old school approach, Get your tv &trailer to a empty lot,Wet the tires a lot and see how the tire marks line up,Then you can see how they are tracking and go from there.
Chris Pastuzyn is offline   Reply With Quote
Old 08-01-2020, 11:56 AM   #5
Oaklevel's Avatar
First take you trailer to a shop that can align your trailer axles (not an RV dealer).
The endurance will be available again soon hopefully, Goodyear closed all of its US plants when Covid started here in March, most are back on line now.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Old 08-01-2020, 12:33 PM   #6
A2pfunk's Avatar
So I looked and it doesn't LOOK like the tire sticks out at an angle compared to the other axle. But it's hard to get a straight on view with them being up in the wheel well.
Replacing an entire and sounds expensive... Maybe I just buy tires more often?
As for the endurance, I find a tire shop that was able to finally get one shipped from another store in Cleveland. Another shop told me they aren't expecting them until October. An actual Goodyear store told me they are on nationwide shortage and that I'd be better off buying a different sized rim or buying another brand.
Old 08-01-2020, 12:34 PM   #7
Palinduff's Avatar
I had this issue also on one of the front tires. I took it in for an alignment and that wheel was way out of alignment. There weren’t many miles on the Puma so I figured it came from the factory like that, the typical great RV quality assurance. If you have to do a turn to park, be sure to pull or back straight back to straighten out the axles. Don’t leave it after a turn for any amount of time.
2017 F150 Eco Boost, SC, 8' Box, 4X4
Max Tow (10 speed, 3:73, 11,700lbs), HD Payload (2440lbs)
2015 Puma 253 FBS
2013 Hyundai Santa Fe
2000 Honda EX 400
Palinduff is offline   Reply With Quote
Old 08-01-2020, 12:38 PM   #8
I would never buy another trailer without immediately taking the trailer to a shop that specializes in axle alignment. I have found that some manufacturers send trailers out without verifying alignment.
JimMorrell is offline   Reply With Quote
Old 08-01-2020, 12:48 PM   #9
Two things I noticed
Looks a little to me like you are running your tires way to low on pressure. When running a proper pressure the wear should be even and I notice you have the same outside wear on the inside of that same tire. Tires wearing on the out side = to low pressure. Tires wearing in the middle = to high pressure.
Next I would suggest that you check your tires and pressure much more often. To be asking this question now with that much wear seems like tires are not being checked often enough. If I am wrong please disregard as I am not trying to criticize but inform and help.
campers302 is offline   Reply With Quote
Old 08-01-2020, 12:54 PM   #10
Linnemj's Avatar
We had the same issue with our 2012 XLR. The RV dealer said we bent the axle, which I highly doubted, so we replaced the axle. The problem continued. When we attended the national FROG rally in 2014, Forest River had us take the trailer to Lippert who had plants nearby. Their tech told us our axle hanger box was out of square on that side. A welder fixed that issue and also fixed several cracks in our frame and added some support beams to the frame. They also replaced the Dexter axle. All of this was done by FR with no cost to us. This solved our issue.
Jim & Nicky
2012 Forest River XLR 29 MBV
2010 Dodge 2500 Cummings
Honda ST1100
BMW R1100R
Linnemj is offline   Reply With Quote
Old 08-01-2020, 12:55 PM   #11
Call lippert. They make the frames. They can send you a measurement chart to check all tire and axle positions to include checking to see if the frame is square. this chart will tell you exactly where to do all the measurements. believe me,, you will know where the problem is after checking everything. I have the Catalina 24 ftr. Dexter axle ended up sending me a new axle assembly after I proved all the measurements. But my 2018 only had 2000 miles on it with Dexter axles,,, not lippert axles. These frames are not made the same year as the trailers. They are prebuilt, then called to the assembly line later when needed. They can be pretty rusty when installed on a "NEW" trailer.
TT: 2018 Coachmen Catalina
243rbs(rear bath) legacy edition
TV: 2017 Ram 1500
Lee Pedrick is offline   Reply With Quote
Old 08-01-2020, 12:56 PM   #12
rsdata's Avatar
Use a board cut to the tire width, like a 2x4, ( make sure it is straight and not warped) then place it on the side of the tire and use a level next to ( on top of) the board to determine whether that tire compares to the one behind it... that is a start anyway... could be from a bent axle from striking a curb or pothole
"Freedom is never more than one generation away from extinction. " - Ronald Reagan
Too much of anything is bad, but too much good whiskey is barely enough. Mark Twain
2014 Shamrock 183
Old 08-01-2020, 01:01 PM   #13
Let's for the moment assume you have a torsion axle. Here's a replacement axle for under $500, delivered. ($348 = $140 flat rate freight)
https://bendtrailers.com/dexter-10-3...CABEgIePvD_BwE
To replace all that's required is removing hubs and backing plates, unbolting from frame, swap, and reverse operation. About half a day and maybe a 6-pack (for you and your helper).
If it's a straight axle with leaf springs here's an axle beam only for $225 + shipping.
https://thetrailerpartsoutlet.com/pr...yABEgJ0nfD_BwE
Since the R&R really doesn't require any special equipment other than jack stands and basic tools this is a frequent DIY project. If you repack your own bearings the rest is fairly simple.
If you do decide to DIY, just make sure any measurement s required before ordering are EXACT. If in doubt place your order via phone.
BTW, I just linked a couple of sources. Axles can be purchased from many different online sources, these were just random examples. Be sure and check e-trailer.com also.
Good Luck.
BTW, one set of new tires will cost as much as a worst case DIY replacement AND you'll still have the problem.
2004 Nissan Titan
Old 08-01-2020, 01:02 PM   #14
He only has wear on the outside edge of this tire. The inside edge is fine. Low pressure would affect both edges. That is not a low inflation issue. Also has only one tire out of 4 doing this.
2017 Coachmen 233RBS
2018 Ford F150 Lariat 3.5 Eco
"Common sense is not very common"
babock is offline   Reply With Quote
Old 08-01-2020, 01:03 PM   #15
X2 I took mine to a good trailer shop and they found a camber issue and the two axles were not parallel with each other. You can't fix that problem by changing the axle.
2012 Cedar Creek 36CKTS Touring Edition
2015 Ford F-350 CC DRW Lariat
Joe_GA is offline   Reply With Quote
Old 08-01-2020, 01:16 PM   #16
For reasons I don't understand, most RV dealers don't have the equipment or knowledge to adjust alignment. Take it to a tire or other shop that has the ability to diagnose and fix the problem.
DrLewie
Flemington, NJ
Former: 2007 Cardinal 30W LE
Now:2018 Arctic Fox 27-5L
2008 Ford F-250 Long Bed Diesel
Total of 30 Months on the Road Since 2008
DrLewie is offline   Reply With Quote
Old 08-01-2020, 01:37 PM   #17
[QUOTE=Joe_GA;2381215]X2 I took mine to a good trailer shop and they found a camber issue and the two axles were not parallel with each other. You can't fix that problem by changing the axle.[/QUOTE]
If his axles weren't parallel he'd have various wear patterns on all four tires. Outside wear on one tire and Inside wear on the other on the same axle. Other axle would be just the reverse.
Single tire wear like in the picture is MOST OFTEN a mis-alignment of only that wheel. Other three wheels/tires are holding the road and forcing that single tire to "scuff along" with it's outside edge wearing from toe-in or excessive positive camber. Probably both.
As for fixing the "axles not parallel" issue, not a big deal. Either a well placed sledge on the forward or rear spring hangar or grinding out the centering hole on the spring pad with a Dremel Tool, and filling the side opposite the new locating pin location with J-B Weld (applying a thin layer of oil or grease on parts you don't want the J-B to stick to) will solve the issue.
If one has a flat surface that they can drive onto straight (no turning action) basic alignment can be done with four jack stands and some Mason's String.
Tie off to one jack stand behind trailer and another ahead. Move jack stands until string touches all four tire's sidewalls on each side.. Just touching one rear wheel and one front then stop. Do this on both
If the line is not touching both sidewalls on all tires you will see any mis-alignment. Now measure from center of coupler, or a hanging plumb line from king-pin (centered on front or rear of pin), to the Mason's Line (also called a chalk line but chalk isn't necessary). This will tell you pretty much how well the trailer is tracking.
Make sure the jack stands hold the string even with the center of the tires and the vehicle has been pulled straight for at least 15-20 feet.
FWIW, this is how alignments used to be done on trailers before expensive equipment came along. It's still done with many race cars in open wheel and even NASCAR when away from the main shop. They call it "stringing".
Some will merely check various reference points using plumb bobs and chalk marks on the floor, measuring the diagonal angles. This works well for checking frames and axles themselves for proper geometry but it doesn't take into consideration any misalignment of spindle to the axle itself and that's where the majority of all alignment problems are located.
2004 Nissan Titan
Old 08-01-2020, 02:06 PM   #18
If is was a loose bearing, the tire wear would be more to the inside of the tire. The OP did not mention if they were first owners on a 2015. It is possible that someone may have put a jack on the axle in the wrong place on that side. That may attribute to the wear on the outer tread and not the other tires. It wouldn't take much of a bow to cause unusual wear.
PenJoe is offline   Reply With Quote
Old 08-01-2020, 02:28 PM   #19
old40ford's Avatar
X2
Retired Auto body teacher
2017 Puma 255RKS
2019 F-250 Lariat Super Crew 6.2
Having lots of Fun traveling with my wife
old40ford is offline   Reply With Quote
Old 08-01-2020, 02:34 PM   #20
Tire wear
Had the same problem. Take it to a trailer alignment specialist. Problem solved.
Do not go to RV place or auto alignment shop.
edkayc is offline   Reply With Quote
alignment, tire
