Old 11-24-2021, 01:47 AM   #1
Unusual tire wear
We had a blowout earlier this year so I replaced all four 15" tires in Barstow. We've probably put less than 3k on them and the right rear is worn to the outside wear bars. The other 3 are wearing normally. It almost appears that the dexter torsion axle or spindle is out of alignment. Any suggestions?
I haven't removed the tire & rim for inspection yet.
Scootertramp is offline   Reply With Quote
Old 11-24-2021, 04:25 AM   #2
wmtire's Avatar
Is the one that is worn out at the same position as the previous one that blew out?
2011 Flagstaff 831 RLBSS
Sometimes, I sit and wonder about what actually happened to all those people I gave directions to.
Old 11-24-2021, 05:58 AM   #3
Nope.It might just be a crappy tire but It's really weird
Old 11-24-2021, 07:18 AM   #4
wmtire's Avatar
Not necessarily. You easily could have something bent or damaged. It's really all guess work though as to if sonething may have been damaged depending on how/where the trailer was jacked up at for tire replacement
Old 11-24-2021, 08:04 AM   #5
TowPro's Avatar
worn to the outside wear bars sounds like the outside tread is worn bad, but center is OK? and this is even wear on both outsides?
could this be under inflation on that one tire?
2019 Forest River Forester MBS 2401R
TowPro is offline   Reply With Quote
Old 11-24-2021, 08:26 AM   #6
Same question here. The blowout could have been caused by a "road hazard" which also damaged the axle.
"A wise man can change his mind. A fool never will."
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 11-24-2021, 03:01 PM   #7
Linnemj's Avatar
We had wear on the outside tread of one tire on our trailer. The dealer told me I must have bent a spindle and convinced me to change an axle. I was sure I never did anything to bend the axle. The problem continued. It turned it that the axle hanger on that side was out of square causing the issue. It was discovered during the Forest River Rally and Lippert repaired it at no charge.
Linnemj is offline   Reply With Quote
Old 11-24-2021, 10:33 PM   #8
Now I know had same problem on my recently traded in Wildcat
moose074 is online now   Reply With Quote
Old 11-25-2021, 01:21 AM   #9
Sounds like bent spindle or axle damaged.
krazyk is offline   Reply With Quote
Old 11-25-2021, 12:15 PM   #10
TGR
TGR's Avatar
One of my trailer's tires wore out on the inside. The problem was the spindle nut was too loose, allowing excessive play, which allowed the tire to wear unevenly.
Premature wear on both the outside and inside of a radial tire would likely be under inflation.
2015 Wildcat 282 RKX
2011 F350 Lariat, 6.7 L. Diesel, 8 ft., SRW, Reese R20
TGR is offline   Reply With Quote
Old 11-30-2021, 12:53 AM   #11
Tire inflation is not the issue. I stay on top of them. I finally got my chainsaws, size by side, Harleys and farm truck up and running so I'll finally be able to get the tire off the 5th wheel for inspection
Old 11-30-2021, 12:59 AM   #12
The blowout was on the same axle but other side. The tire that blew was an original and the set had around 10k on them, with relatively even wear.I had planned on changing them at the end of vacation but the Mojave Desert had other plans.
Old 11-30-2021, 01:02 AM   #13
It actually looks out of square! I'm guessing there's no easy way to align the torqueflex axles...lol
Old 11-30-2021, 01:12 AM   #14
I used a roll up on the other axle to change it out with the spare. We had to leave the trailer at the little tire shop because they were the only place willing to take the job on since it was late Saturday afternoon, plus we have a 150lb dog and another little mutt that needed to stretch their legs, so I don't know how they jacked the axles up.
Old 11-30-2021, 01:19 AM   #15
Thanks for the input gents. It'll be awhile but I'll try to give an update once the problem is solved.
tire
