Originally Posted by benchmarks
I know the wheel manufacture is Lionshead and I want to know what the max psi for the wheel is on there JAGUAR ALUMINUM WHEEL.
Wheel Specifications:
Size: 14 x 5.5
Bolt Pattern: 5-4.5
Maximum Load (lb) : 1900
That's all the website says. Does this give me enough information to tell me that I can run x psi tires without a concern of rim compatibility?
Jaguar Aluminum Wheel
It means you can use whatever inflation pressure is needed to provide up to and including 1900# of load capacity. Was the web site a product of the wheel manufacturer? If not, ask them. They are required by FMVSS standards to provide you that information.
Note: It's almost always recommended to use bolt in valve stems on trailer wheels.
