Originally Posted by doc73
More and more are starting to come in with a higher rating for speed. I think a govt thing changed and made the increase. Even the china bombs are coming in with 75 80 or 85mph rating anymore.. IF you get new stock not one sitting on the shelf for years.
Originally Posted by SailorSam20500
Look at the picture of the tire on the page. They show a P225/60R16 98H. The "H" is the speed rating. From the table lower on the page, this tire is rated for 130 MPH. Your trailer tires are probably in the G-L range 55-75 MPH. As noted in the document, Speed and load range are not required by law so may not be printed on the tire.
I thought the H was the load rating? Wheres the TIRE GUYS!!!
Man, so many things going on in this thread.
1. OK, starting with Doc73's post about the govt changing the mandates on ST tires and speed ratings. This had to do with import tariffs as much as anything.
It was discussed previously in this thread:
http://www.forestriverforums.com/for...ml#post1138004
2. Ok, for SailorSam's post. Passenger tire sizes had a different Load Speed Index system than ST tires since ST tires previously were pegged out at 65 mph. This has changed, see # 1 above, hence you may commonly find a L speed rating on ST tires now as well as a speed/load index system similar to passenger tires. Also ST tires have a ply rating factor where passenger tires do not.
Tire Rack has a lot more detailed explanation that explains the differences between the two systems, located here:
https://www.tirerack.com/tires/tiret....jsp?techid=35
and here
https://www.tirerack.com/tires/tiret...jsp?techid=55&
3. Doc73's second quoted post is explained in #2 above with the link to Tire Rack who has the charts for the speed/load index numbers.
Also the speed ratings are not truly alphabetized.
The Origin of Speed Ratings
We can thank Germany’s famous Autobahn for tire speed ratings. Tire speed ratings range from A (the lowest) to Y (the highest). But the chart is not completely in alphabetical order. For example, H is between U and V, with the common perception that H stood for “high performance” at one time. As manufacturers continue to add speed to their vehicles, tire speed ratings evolve to match the speeds. For example, Z was the highest rated speed at 149+ until W & Y were used to match the higher speeds of exotic sports cars.
Hope this helps, or at least doesn't confuse the issue further.
