Closed Thread
Old 10-16-2018, 10:20 AM   #1
Denver To Yuma In 90 Days
Question Why do tire makers mould the max PSI in such small print on the sidewall?
I've often wondered why tires always have the tire pressure listed on the side of the tire in such small print that you need three pair of readers stacked and a microscope to see what it is.
Do they not want us to know that number...or what?
Why don't they put that number (max tire pressure) as large as the tire size is moulded on the sides of the tires?
JohnD10 is offline
Old 10-16-2018, 10:24 AM   #2
wmtire's Avatar
You mean something like this.
2011 Flagstaff 831 RLBSS
I often say to myself, "I can't believe that cloning machine worked."
wmtire is online now
Old 10-16-2018, 10:29 AM   #3
Attachment 189351
Yes!
But that is not the norm...
What tire is that?
JohnD10 is offline
Old 10-16-2018, 10:31 AM   #4
D W
D W's Avatar
Since all the tires in the US are that way I would venture to guess that it's a regulatory requirement, .i.e type of lettering, size of lettering and location of lettering. If you have ever read 49 CFR you will realize that USDOT has an affinity for "labels & markings".
2016 Salem 27RKSS
D W is offline
Old 10-16-2018, 10:39 AM   #5
wmtire's Avatar
Originally Posted by JohnD10 View Post
Yes!
What tire is that?
That is a Carlisle HD
Old 10-16-2018, 12:02 PM   #6
RV There Yet?
IsleDog's Avatar
thats impressive that you know that just from looking at that! looks exactly like the ones i had on my popup. to make that even easier to see, you can use your white grease pen to make it stand out. yes it fades and turns brown, but its readable form 10 feet away!
I have taken to marking tire pressures with the grease pen no matter the size. just helps me find it on the tire. you could just mark the pressure larger anywhere on there too. not pretty looking though
IsleDog is offline
Old 10-16-2018, 01:15 PM   #7
wmtire's Avatar
Not really impressive. I took the pic of it in the second post. We stock them, and I just pulled one off the rack and snapped a pic with my phone.
Old 10-16-2018, 01:35 PM   #8
Tire press readability
I have said for years that the government would have accomplished more by making the requirement to have the max pressure and load rating a minimum size of 3/4”, than requiring a tire pressure monitoring system that has less features than the aftermarket units and is so costly to replace the batteries. But that’s what happens when the government and special interest money makers get involved. Tire makers have no trouble making the name big letters.
aircommuter is offline
Old 10-16-2018, 01:37 PM   #9
RV There Yet?
IsleDog's Avatar
Cheater...you could have left us all in awe of your impressive tire knowledge
IsleDog is offline
Old 10-16-2018, 01:37 PM   #10
What manufacturers are hoping
They want you to return to the tire dealer to read it for you. While you are there they can change your shocks, do a front end alignment, check your ball joints, and refill your muffler fluid.
2018 Rockwood 2509S Mini Lite
Past: 1984 Road Ranger 20', 1988 Kit Companion
1984 Starcraft 24 foot popup
TV: 1999 Dodge 2500 Cummins 4x4
Honda EU2200i Generator, 300 Watts Solar
Ham Callsign KD7UM
UT_Grandpa is offline
Old 10-16-2018, 01:38 PM   #11
WHY? WHY?
My thought exactly, just came in from crawling around on my knees with a flash light trying to read it. There is not a good reason for it to be so small, plenty of room.
pdqparalegal1 is offline
Old 10-16-2018, 02:20 PM   #12
Did you forget about checking the muffler belt? That thing has to stay tight!
AFDON is offline
Old 10-16-2018, 02:26 PM   #13
amblt's Avatar
Somewhere in all governments is the "This will screw them up" branch. It's located in a cold, damp windowless basement room and staffed by little old bitter grey haired men. That's where these decisions are made. In Canada, it's probably located in the most remote part of Saskatchewan. (yup, that's a real place- you can google it).
Cheers
amblt is offline
Old 10-16-2018, 02:57 PM   #14
[QUOTE=amblt;1951634]Somewhere in all governments is the "This will screw them up" branch. It's located in a cold, damp windowless basement room and staffed by little old bitter grey haired men. That's where these decisions are made. In Canada, it's probably located in the most remote part of Saskatchewan. (yup, that's a real place- you can google it).
Here in the states it's located in Washington. They're call the Senate, and House of Reps. :trink 39:
ard58 is offline
Old 10-16-2018, 03:06 PM   #15
I have Goodyear Endurance tires and 65 PSI Max is almost as big letters as Goodyear. Car tires are a different matter, you need a magnifying glass to see it.
Wolf26 is offline
Old 10-16-2018, 03:23 PM   #16
Old Engineer
FleckDreher's Avatar
Use a label at the valve stem.
Once I find it I make a label and put it at the valve stem.
Clean off the wheel with alcohol first and the label will stick good.
2019 Dynamax Isata 3 24RW
Smart Car Towed 4 Down
Quote: "When all else fails, read the manual!"
FleckDreher is offline
Old 10-16-2018, 03:34 PM   #17
For old dudes
They do that to make sure us old dudes get our exercise doing deep knee bends.
kirkwilliams2049 is offline
Old 10-16-2018, 03:42 PM   #18
Mr Towed's Avatar
I mean, he POSTED the picture, he TOOK the picture, he was there to see the rest of the tire that is not included in the picture.
Travel Trailer: 2004 Flagstaff 25LB
New Tow Vehicle: 2017 F-150 3.5 Ecoboost, supercrew short bed FX4 Lariat
Old Tow Vehicle: 2009 Silverado 2500HD 4x4 Ext. Cab Short Bed
Travel Pooch:Sophie the Sato - Cats: Rhody and Hazy
2018:22nights / 2019:31Nights / 2020:18Nights
Mr Towed is offline
Old 10-16-2018, 03:45 PM   #19
D W
D W's Avatar
Or, you can do it the Army way and just stencil it on the fender!
2016 Salem 27RKSS
D W is offline
Old 10-16-2018, 04:16 PM   #20
Old Engineer
I do that on all my Army Trucks.....
Closed Thread
tire
