Getting ready to hit the road so it was time for the yearly inspection of the TT running gear and I found a couple issues.
First issue, lug nut refused to come off so I hammered a slightly under size socket onto the lug nut, it come of but cost me a socket, split it. It's a Snap-on socket so I'll see if I get it replaced.
Second issue found small cut on one of my GY Endurance tires. Let my tire monger inspect it, told me it's not an issue as its no deeper than the factory tread slits.
Third issue, brake that was dragging. Adjusted the brake, backed it off turn or so, working fine now.
Do those yearly inspections, don't want to learn the hard way you have a problem.
