we have a 2015 cardinal with washer / dryer prep. i'm assuming the washer plumbing is similar to yours. the only shut off valves that we have on the hot and cold water spigots are right on the spigot itself. there is a lever on the spigot that you have to rotate 90 degrees to allow water to flow out the spigot. this is the way it came from the factory.
if you bought from a previous owner there may be user installed valves somewhere. who knows?
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
