Old 06-18-2023, 01:21 PM   #1
Air Conditioner has no power
Please Help! Air Conditioner has no power going to it. I've checked the shore power, the breakers, changed the thermostat. No power to ac & thermostat. Every thing else in 04 Forest River Cardinal 29 LE works great. AC worked perfect last summer. It's getting hot in NM - need my AC working to keep me & 4 Chihuahuas cool.
GoneCrazy2013 is offline   Reply With Quote
Old 06-18-2023, 08:29 PM   #2
Campzoo's Avatar
How's your batteries? The thermostat runs off the batteries. If it don't have power the ac won't work
Campzoo is offline   Reply With Quote
Old 06-18-2023, 10:26 PM   #3
No power to Air Conditioner
Yes I checked batteries . They good. Fuses good
Old 06-19-2023, 12:53 AM   #4
Welcome to the forum!
You've got a 2004? How did you test the battery?
You may need a mobile mechanic to try to trace down why you're getting no power to the thermostat or battery. You may need a new airconditioner, but you need to find out if it's the wiring or the unit itself.
2015 Dynamax REV 24TB class C
Reverse_snowbird is offline   Reply With Quote
Old 06-19-2023, 06:57 PM   #5
On a 2004
The OP's trailer is a 2004. The original thermostat is completely mechanical. No batteries involved. (For A/C use, it's powered by the low-voltage transformer within the A/C.)
One of the good reasons to avoid replacing it with a "digital" thermostat is that you introduce new failure modes.
Larry
Larry-NC is offline   Reply With Quote
air conditioner, no power, power
