Old 09-26-2020, 04:54 PM   #1
Battery disconnect
We have a new Cardinal Luxury 345rlx. We just completed our initial trip of three weeks. I put the RV in storage attached to trickle charger. On our former coach we just hit the storage battery disconnected switch. Is it the same for this RV? I removed the battery disconnect pin to disconnect battery but wanted to check.
Texas Traveler
Cypress, Tx
2020 Ram 3500 DRW Cummins Longhorn
2020 Cardinal Luxury 345RLX
SteveE9C6 is offline   Reply With Quote
Old 09-26-2020, 07:27 PM   #2
No, the factory disconnect does not disconnect everything. I installed another disconnect right at the battery for this reason. LP and CO detectors bypass the disconnect for liability reasons.
Dave
2017 Cardinal 3850RL Mocha Pearl full body paint
2016 F350 Lariat 4x4 FX4 SRW CC SB 6.7 Magnetic Metallic
djousma is online now   Reply With Quote
Old 09-26-2020, 07:58 PM   #3
if it is like our cardinal the factory installed battery disconnect is useless. i think i found 5 separate devices that still draw battery power even if the factory disconnect is set to off. i installed my own disconnect right at the batteries and it disconnects all devices.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
CHICKDOE is offline   Reply With Quote
Old 09-27-2020, 08:24 AM   #4
What battery disconnect switch did you install. I need to fo the same thing with my 2020 3456rlx. I have two batteries installed.
Hawkpat is offline   Reply With Quote
Old 09-27-2020, 08:38 AM   #5
in my case i installed a Marinco battery switch. you will also need an additional battery cable to go with it. there are several others. you can also use a quick disconnect on the battery cable right at the battery terminal found in the auto parts stores.
Old 09-27-2020, 12:09 PM   #6
Just as confused as you
Scrapper's Avatar
Which battery disconnect pin did you remove? If it's the one on the hitch a-frame with the cable it is your break-a-way switch for the brakes in case the trailer becomes disconnected from the tow vehicle and your brakes will then have continuous power from the battery.
I'm asking because not all battery disconnects have a removable handle or pin.
Richard & Jill
Camping since 1989
I deserve hazard pay when camping with my relatives.
Old 09-27-2020, 03:35 PM   #7
I removed the pin in the basement storage wall labeled battery disconnect.
What I am curious about is if the battery continues to trickle charge when this is disconnected. Our previous diesel coach batteries continued to charge when battery disconnect was engaged.
Texas Traveler
Cypress, Tx
Old 09-28-2020, 11:19 AM   #8
If you are connecting the trickle charger directly to the batteries, then yes, they will still charge. I have found that is not really necessary if they are fully charged when put away, and the battery is disconnected completely.
I do know (from experience), is that if the factory installed battery disconnect is turned off, that the converter will NOT charge the batteries if connected to shore power.
Dave
battery, battery disconnect
