Old 10-04-2023, 08:06 PM   #1
Cardinal 2018
I have a 2018 Cardinal 3825 FL with three ACs. Does anybody know which one is 15K.It is supposed to have one 15K and two 13.5Ks?
whj469 is offline   Reply With Quote
Old 10-05-2023, 06:22 AM   #2
On my 2017, that is the rear A/C. Looking at the units from the outside, the 15K unit is also a bit taller.
Dave
2017 Cardinal 3850RL Mocha Pearl full body paint
2016 F350 Lariat 4x4 FX4 SRW CC SB 6.7 Magnetic Metallic
djousma is offline   Reply With Quote
Old 10-05-2023, 09:47 AM   #3
one our 2015 we only have two a/c's. the rear one is the 15K unit that has the built in heat pump. the front a/c is 13.5K with no heat pump.
do you have your build sheet? look at it to get the a/c model numbers and locations.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
CHICKDOE is offline   Reply With Quote
Old 10-05-2023, 09:23 PM   #4
Thank you to both of you. The rear, bedroom AC, is taller then the other two.
cardinal
