Old 09-05-2020, 04:20 PM   #1
Door Opening on 3150rl
Hi All,
Are the entry door openings on the Cardinals all the same. I have a chance to make a deal on a set of LCI Solid Steps and would like to know if the steps will fit. My RV is in the shop and I can’t get there to measure the door opening. The steps are 26”. Thank you in advance for your answer.
Ddozier234 is offline   Reply With Quote
Old 09-05-2020, 05:34 PM   #2
Retired JSO's Avatar
Is this a new trailer? Our 2018 Cardinal came with morryde steps.
Retired JSO is offline   Reply With Quote
Old 09-05-2020, 07:43 PM   #3
JSO, It is a 2011 3150rl. I want to upgrade the steps to match the new.
Old 09-25-2020, 11:42 PM   #4
Steps
You should no before putting the new style steps nn that in tight spots such as rest areas you can not put them out also if it is raining when you are putting them away it's going to get wet inside the trailer. Hopes this helps?
donabevd is offline   Reply With Quote
Old 09-27-2020, 06:42 PM   #5
The Newsoms's Avatar
We put some on our 2016 3825fl. I like them when they’re down but not so much when they’re up. They’re in the way.
The Newsoms is offline   Reply With Quote
door
