04-29-2020, 01:50 PM
Has Any One Used FlexSeal?
I found out last night during a thunderstorm that the skylight above my shower has several spots that has spiderweb cracks and is leaking. I have a can of paint on FlexSeal could I use this instead or replacing the skylight itself?
Leah, Wayne, Max & Beignet
2008 Ford F-450 King Ranch 4X4 6.4L
2008 Cardinal 30LE
04-29-2020, 02:04 PM
04-29-2020, 02:07 PM
Just as confused as you
If you check the Flex Seal website and click on each item you will see the disclaimer for Temporary Repairs only.
Richard & Jill
04-29-2020, 03:00 PM
Flex Seal
I just used it. After waiting awhile, I went back to check on it and it did not stick. I used Eternabond and as of now still sticking. Put it around my backup camera.
Mike
Mike Gray
Forest River Wildwood
2017 27 RKSS
2015 Sierra SLE 5.3 V8 4x4
04-29-2020, 03:18 PM
its a temporary repair at best if it even works
2011 gray wolf 25rb
04-29-2020, 06:15 PM
Flez Seal
I have used Flex Seal clear in the spray can on leak in slide out. Stopped the leak and didn't return as long as I had the MH - 4 or 5 years after using.
Paul 2019 Forester.
04-29-2020, 06:40 PM
It is a " Quick short term solution "....thin caulking cracks on roof...blow water out with hair drier...then spay with flexseal ! Stuff will evaporate turn to powder in 30 days n blow away...BUT IT WORKS IN THE SHoRT TERM
04-29-2020, 08:56 PM
Great product
Yes, we had a leak snd used Flexsesl. Works like a charm. The leak was on the right hand corner of the cab if our Class C Forest River MBS. I thought my husband was nuts to use it; however, he decided to try it, snd one yesr later, no more leak. Yes, use it.
04-29-2020, 09:30 PM
I sprayed some pinhole leaks in a small duck boat and it lasted the entire season including some short drags over gravel.
2021 2205S Rockwood Minilite
2019 F 150 Lariat 3.5 Eco Fx4 Max Tow
Equal-i-zer WDH, 1809 lb payload
04-30-2020, 06:23 AM
Repair the problem right the first time, if you don’t, it will return.
Jim & Pam
2017 Ram 3500, Crew Cab Diesel Dually
2014 Hemisphere 327res
04-30-2020, 07:12 AM
X2
2016 Coachmen Apex 250RLS Ultra Light 2023 Ram 2500 Big Horn Sport 3.73
04-30-2020, 07:25 AM
I used it for the last time
I used it on my gutters on my home. My corner joints was leaking so I cleaned and scrubbed them real good so it would have good clean foundation to adhere to. It worked good for a while and when winter set in and it got cold,( below freezing) the seal let go and they all started leaking again. Now I have to get up there and some how clean the flex seal out and use gutter caulking that I should have used it the first place. I guess if you want to make a boat out of a screen door , then use it !!!
04-30-2020, 10:01 AM
FlexSeal failed
I used it in a few places. It failed to seal. I threw out what was left and made a mental note to never try it again. It was applied as directed to seal rain gutters. Total failure.
2012 Rockwood Windjammer 3008 W
2020 Tundra Dbl Cab 4X4 SR5
04-30-2020, 10:08 AM
Boss Ox & Drovergirl
I used the FlexTape to successfully patch tears in the roof as a result of storm damage from tree limbs. It worked well, but I ended up getting the entire roof replaced through my insurance.
Mark, Vicki, & Scout THE dog
2015 Hemisphere 282RK
2016 GMC 3500HD Duramax dually
1992 Goldwing Aspencade
04-30-2020, 10:30 AM
as many know it's how supervises is prepend I found flex seal sticks well when done right won't stick long to dirty stuff. I just got the new paste now that's the cat's behind LOL
04-30-2020, 11:13 AM
It would be nice if the guy in those commercials went out and uses his boat (or any other repairs) 2 or 3 months later. See how his boat really stands up
2015 Flagstaff 32IKBS
2008 F350 6.4
1999 Palomino Filly Popup (my daughter's now)
04-30-2020, 11:22 AM
It sank
I would bet it sank and they're still looking for him !!
