Old 10-28-2021, 04:44 PM   #1
Inverter not working
We have a new 2021 Cardinal 5 th wheel parked in a rural area. The area has lost power due to a storm and we were under the impression the inverter would kick on. It did not and I can’t get it to turn on manually either. What is wrong and what can I do.
Eimac is offline   Reply With Quote
Old 10-28-2021, 05:55 PM   #2
What do you expect it to run, residential fridge? Can you take a pic of te front panel? Do you have a remote start node?
2016 Siverback 33IK, Towed 60K+ mile
Old 10-28-2021, 06:03 PM   #3
rsdata's Avatar
chances are the inverter is only hooked to select circuits NOT the entire trailer...
2014 Shamrock 183
Old 10-28-2021, 07:11 PM   #4
depending upon the model of the inverter there may be a GFCI protected receptacle on it that the output load is plugged into. check to see if the GFCI has tripped.
what does the display panel on the inverter show? is it on? is it generating output power. are there any error codes?
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
CHICKDOE is offline   Reply With Quote
Old 10-28-2021, 07:32 PM   #5
The display panel
On the remote node and the inverter itself will
Not turn on.
Old 10-28-2021, 07:33 PM   #6
Both the inverter and the remote panel are not on.
Old 10-28-2021, 07:35 PM   #7
I expected the light to work. The inverter is not showing anything. It’s a brand new RV. We were told it would
Kick on if the power went off and it didn’t. No lights. Nothing shows on control
Panal
Old 10-28-2021, 07:56 PM   #8
I don’t know what inverter you have but mine requires the push button on the front panel to be in a certain position. I don’t have a remote button so I’m not sure what position it needs to be. I suggest you go to the inverter and press the button one time and then try the remote button.
Old 10-28-2021, 07:58 PM   #9
Is your fridge on?
Old 10-28-2021, 08:33 PM   #10
Here is how my inverter operates….I don’t have an indoor remote button..
https://youtu.be/pf7NhvBu3U0
Old 10-28-2021, 08:45 PM   #11
PopFla's Avatar
Chances are your battery disconnect switch is off. Make sure it's in the ON or USE position. If the battery is charged and the switch is on, all your 12 volt devices, including the control panel, should work.
2018 Georgetown XL 377TS
2020 Jeep Gladiator "Toad"
CAMPING (n. CAM-ping) - When you walk the dog in your pajamas with a cup of coffee in one hand and a bag of dog poop in the other while striking up a conversation with total strangers.
PopFla is offline   Reply With Quote
inverter
