Old 04-24-2019, 03:57 AM   #21
nomad297's Avatar
What was your final solution with this? It may help a member with a similar thread going right now.
Bruce
Old 04-24-2019, 04:40 AM   #22
"On the road again"
rjshiflet's Avatar
Our Cardinal has a pull-out faucet head with sprayer and we had terrible flow early in our ownership...unless I pulled the head out for spraying, then it was fine. I discovered the counter-weight under the sink (in our island) was placed wrong and was causing a kink in that hose...thus restricting the flow.
I loosened the weight, moved it six inches then tightened it - problem solved. You might check that while you're checking other issues if it isn't already resolved.
Robert & Estha Shiflet
Georgetown XL 378TS
Jeep Gladiator Willys Tow Vehicle
rjshiflet is offline   Reply With Quote
Old 04-26-2019, 01:42 PM   #23
The Newsoms's Avatar
If hot and cold both slow, then it’s got to be in the faucet?
The Newsoms is offline   Reply With Quote
Old 04-29-2019, 05:46 PM   #24
OP here. Issue was debris in the line, at the quick connect in the pull-down hose. I had already purchased a replacement faucet from Amazon, about $65, practically identical. Replaced in about an hour. Good to go.
As a previous commenter stated, it was clearly a flow problem, not a pressure problem. It's easy sometimes to overthink things, which my Water Supply Engineer brain tends to do sometimes.
Thanks everyone for the feedback!
2018 Forest River Cardinal 3350 RL
2016 Ford F350 6.7 Diesel SRW
GilnJo is offline   Reply With Quote
faucet, pressure
