10-09-2018, 11:05 PM
#21
I leave mine in. I use a Coleman 3.5w battery tender solar panel to keep it healthy. Panel is pointed SW-ish. Battery was fully or nearly fully charged every time I checked it. As noted, a charged battery will not freeze until temps approach -90 f.
Biggest reason I see for pulling a battery is if you store your rig in a place where it might grow legs.
Al
I am starting to think, that I will never be old enough--------to know better.
Tolerance will reach such a level that intelligent people will be banned from thinking so as not to offend the imbeciles. Fyodor Mikhailovich Dostoevsky, Russian Novelist
S.E. Mich. Flagstaff 26FKWS / 2022 F-150 3.5 EcoBoost SCrew Propride
10-10-2018, 05:22 AM
#22
I take them (2) out and use a battery tender for them. I gives me the opportunity to look them over and clean the terminals or service them. Do what works for you.
10-10-2018, 05:51 AM
#23
NH Maple Maker
I fully charge mine and leave it in the camper. I also disconnect the negative cable to remove any chance of a parasitic discharge. The chemical reaction inside the battery slows down as it gets colder and the battery will actually last longer stored in a cold place. I've never bothered to top up the charge while it's in storage and it's always good to go in the spring.
Russ
2014 V Cross VIBE 822VRBS
2017 Silverado 1500 crew cab 4x4
10-10-2018, 09:20 AM
#24
Maintenance of course is key. Water levels etc. I leave mine in and never have a problem, but I don't trust the trailer converters. They are generally cheap and do not have battery maintenance circuitry. (I'm sure there are better ones, but a not in your average trailer.) I use the chargers listed below from HF. They work great, keep the battery level up, and are not expensive to buy. I set mine up to plug directly into the solar plug in, (just a simple outlet direct to the battery), and my batteries stay charged and last for years.
https://www.harborfreight.com/4-amp-...ner-63350.html
2003 Duramax
2017 Crusader 315
2016 Boston Whaler Montauk 150
Former Montana owner
Colorado Cruiser, Over the Pass and Down the Hill
10-10-2018, 09:37 AM
#25
Can you start the engine mbs 2400 sunseeker with the coach batteries removed . I am not sure if it would damage any of the charging systems.
Bob
10-10-2018, 01:33 PM
#26
Denver To Yuma In 90 Days
I just bought that very same charger at an HF store last week for my shed...
Now that cooler temps are here I'll be getting a solar charger to keep in the 5'ver so that I can keep my battery back in the camper, hooked up and charged!
Saw a nice one at O'Reilly's Auto Parts that I'm interested in.
Winter is our camping season down here in the desert southwest.
10-15-2018, 06:30 PM
#27
I live in a cold climate so I have to take mine out. It gets too cold for too long.
Patrick & Cecilia
2012 GMC Sierra 2500 HD Crewcab Duramax
2014 Forest River Tracer 2750 RBS
Honda eu3000 Generator
2015 Nights Camped : 37
2014 Nights Camped : 33
10-15-2018, 06:45 PM
#28
Originally Posted by Chuck_S
Honda S2000
-- Chuck
Awesome car!
Nigel & Bev
Brit Driver & Canadian Naviguesser
We summer in Cowichan Valley BC Canada & winter in Monchique Portugal great camping in both!
2011 Rockwood Signature Ultra Lite 8280ws 2011 Dodge Ram 3500 4x4 Diesel 2000 Honda S2000
10-15-2018, 08:26 PM
#29
Like others I used to remove, take home to garage, put BATTERY TENDER on battery. I now leave both batteries in RV, remove cables, connect BATTERY TENDERS to both batteries. Getting too old or lazy to lift this stuff!
2019 CC Hathaway 36CK2
2006 Ram 3500 Dual Wheel Cummins
Fleetwood PA
10-15-2018, 09:10 PM
#30
Senior
X2.
After reading this post I will leave my batteries in the coach with the negative cable disconnected. Do not have electric available where I store and we get lots of snow so my solar would not work covered with a foot or 2 of the white stuff here in the Colorado Rockys.
10-15-2018, 11:51 PM
#31
I've never disconnected my battery during the winter with the power turned off. When I open up for the season, I hear the converter running I'm assuming to charge the battery. Good all season.
10-16-2018, 09:29 AM
#32
I've done it both ways......but recently I remove the battery and store in the garage on a trickle/maintenance charge. Mainly just to keep it warm if nothing else. I un-plug and cover the Salem Hemisphere Lite. I'm getting close though to heading south this time of the year in the future (hopefully) and I won't have to worry about it anymore!!!
Salem Lite Hemisphere 232IS
Ford F-250 Super Duty Lariat Crew Cab v-10
10-16-2018, 09:44 AM
#33
I've always pulled mine, stuck them in garage and they sit hooked up to a battery tender all winter. Cord hanging off a trailer, is a ladder for a mouse....if you have the "pass thru" cord and not the receptacle on the side.
10-16-2018, 10:14 AM
#34
My first 5th wheel I installed a disconnect switch. I turned it to off and left the battery in for a Wisconsin winter. In the spring, turned the switch back to on, run the 3 slides out and connected to shore power. Did this for 9 years with original battery until traded. It may still be working for all I know. Our current CC, I turned disconnect to off and batteries were dead in spring. There is drain even with switch off. So this time took batteries out and brought home.
Cedar Creek 2018 38FBD
10-16-2018, 10:32 AM
#35
Probably has more to do with the cheap batteries our dealerships install than a power draw with the disconnect switch still allowing draw when turned off.
10-16-2018, 10:48 AM
#36
Originally Posted by No more shoveling
Getting ready to winterize the 3250. In years past I have always left the batteries in and left the camper plugged in all winter long. Is it better to pull the batteries and leave the camper unplugged for the winter. My concern is over charging the batteries over the winter months which did happen on our last camper. If I don't leave it plugged in the batteries will be dead come spring time.
I leave mine in but have a battery disconnect. I turn it to off and in the Spring when I get it out of indoor winter storage I turn it on and no problems
10-16-2018, 02:40 PM
#37
Seasonal condition for batteries
If you choose to leave the unit plugged in you will need to check the water level in the batteries. During our Walk Thuroughs i suggest to our customers to check the water in the batteries every two weeks. thats not saying water will need to be put in the batteries every two weeks but you will catch it in time if they do need to have water put in them. Also if you are keeping the unit plugged in durning the winter leave you fridge on this may lengthen the life of the fridge by keeping the fluid in the core flowing so not to allow a blockage.
10-17-2018, 07:43 PM
#38
Always pull ours, put it in the basement and put a tender on it. Battery test in spring always reads full charge. I am getting too old to tote that anchor in and out and up and down, so this may be the last time it spends winter in paradise.
Cheers!
FROG IL-0076-090
2016 Wildcat 323RBX, 1992 Excel Legacy "guest house"
98 Honda Shadow ACE, 78 Honda CB400A Hondamatic
Nights camped: ‘18 - 27, ‘19 - 27, ‘20 - 30, ‘21 - 49
10-18-2018, 06:16 AM
#39
My Cardinal came with factory disconnect switch, but alas, I assume for liability reasons, it is not a true disconnect. Certain items, mainly LP detector are still powered. Kinda defeats the purpose of battery disconnect. I installed another disconnect right at the batteries. I leave my batteries in the bird all winter. No problems.
Dave
2017 Cardinal 3850RL Mocha Pearl full body paint
2016 F350 Lariat 4x4 FX4 SRW CC SB 6.7 Magnetic Metallic
10-18-2018, 06:25 AM
#40
My 5th wheel had no battery disconnect switch. I disconnected the cables from the battery for a couple of years. I then installed a Blue Sea disconnect at the battery as you have. Works well. Simple flip of the switch
