11-20-2021, 11:26 PM
Pin box has upward angle
My pin box is angled up at the front the trailer is 8 degrees nose high according to the leveling system has anyone had this problem and does it look like a problem
11-20-2021, 11:28 PM
11-21-2021, 07:22 AM
No it shouldn't be a problem your hitch head tilts.
A problem is when it angles down like the TrailAir like I have. It makes it difficult to un-hitch. What I have to do is barely drop the front landing gear and then pull the truck away and of course it then springs up. You can get in spots that make it very difficult to pull out from under it.
Moral of the story is you have a better setup that way.
11-21-2021, 08:36 AM
Who Dares, Wins
My first question would be has your PIN box always been angled upwards?
If it's started to angle upwards and never was before then yes I would be a little concerned because something is making it start pointing up. Probably not even remotely similar to your situation but we recently had some issues with our fifth wheel. During the process of figuring out what was wrong we removed the pin box and found that Forest River used half inch bolts that were grade 5 in a 1 inch hole on the bracket for the pin. Needless to say the bolts were able to bend and because they were a half inch smaller than they should probably have been they were able to move so the whole pin was able to shift within the bracket.
2015 Chevy HD D-Max
2022 Impression 315MB
11-21-2021, 09:24 AM
It should not look like that, and yes it could be a problem as it may indicate that the mounting hardware is loose. If someone hangs on it, does it move back down? If you look closely around the mounting bracket and the bolts, inside and out, can you see indications of movement where paint has been rubbed/scuffed or metal has been polished or scratched?
Dave in SK
VE5DLC
Trailer: 2011 Cedar Creek Silverback 35K
Truck: 2006 Dodge 2500 TRX4 Cummins
Seasonal at Saskatchewan Landing Provincial Park
11-21-2021, 09:53 AM
first thing I would do is look at pictures of other (what is your RV?) and see if they look the same.
11-21-2021, 09:58 AM
Looking at the damage to your nose of the trailer, did you drop it off the hitch? Angled like that is not something I have ever seen before. Either the hitch is loose, or something is broken where the pinbox connects to the frame, or the frame itself.
Dave
2017 Cardinal 3850RL Mocha Pearl full body paint
2016 F350 Lariat 4x4 FX4 SRW CC SB 6.7 Magnetic Metallic
11-21-2021, 11:28 AM
Don't think we have the whole story here. What caused the damage? Has the hitch always been that way?
If you can't tell or don't already know what is causing the hitch angle, call someone qualified to gain access to frame and evaluate what is going on.
Then go from there.
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
11-21-2021, 11:49 AM
It was dropped, you can see the tape on the cracked/ damaged fiberglass.
XLR Thunderbolt 300X12HP
2014 Ram 3500 DRW
11-21-2021, 11:55 AM
I think we all agree some accident type of event happened to the RV. Hitch angle probably related to the damage on the front cap, but that is just a guess. The best thing for the OP to do is call his insurance and let the adjustor evaluate it.
11-21-2021, 12:15 PM
Who Dares, Wins
Yep missing some info here.
2015 Chevy HD D-Max
11-21-2021, 01:32 PM
My Wildcat did that and worse on a trip home from the lake. The 2”x8” metal beams surrounding my pin box tore - some completely through. A major front-cap-off welding job was required - mostly covered by my extended service contract.
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 = 111/'19 = 86/'20 =108/'21 = 115/'22 = 135/'23 = 78/'24 = 97; Booked for 2024 = 28
11-21-2021, 02:47 PM
I'm no expert but that doesn't look right. Did someone change the angle trying to change your nose high position? You need to get a pro to examine it.
Cedar Creek Lake, Texas
2019 Keystone Loredo 290SRL
Andersen hitch
11-23-2021, 10:10 AM
response to pin box
I don't want to get to wordy about this but what has happened is that your upper deck has structural defect. I just went through this this summer replacing my upper deck. If you want to discuss please reach out via private messenger
Changing it up a bit
2017 40 ft Cardinal Estate
2014 SRW Chev Duramax 3500
Titan 50 gal fuel tank
Air Lift 7500 lb bags
