We had one of ours do the same thing. To pull the drawer out, look at the slides on the side of the drawer, there should be a small plastic tab in the end of the moving portion on each side. One of them you lift, the other side you push down then just pull the drawer out. On ours the problem was with the soft close mechanism at the rear of the slide system, there was a cap that came off and there was a spring hanging out. Since ours had to go back for floor replacement the factory replaced the slide while it was there. It looks like it is not really a big job to replace if you know how to run a screwdriver.
(Previous) Coachmen Mirada Select 37RB
(Previous) Coachmen Freedom Express 246RKS
(Current)2022 Grand Design Reflection150 226RK
2022 F150 Powerboost Hybrid.
