Old 11-10-2020, 02:24 PM   #1
Water heater bypass location
I have a 2020 Cardinal Limited. Does anyone know the location of the water heater bypass valves? Thanks!
JPSCOTT123 is offline   Reply With Quote
Old 11-10-2020, 02:34 PM   #2
Kanadian Kamper
kenandterry's Avatar
If youíve located your actual water heater, youíll usually find the bypass valves are within inches of the lines into and out of the tank. Sometimes that means removing false panels or removing drawers. On my Class A, there was an access door I had to access from underneath the motorhome to reach up inside to get to the valves. My present motorhome has a false panel I remove located underneath the kitchen sink.
Ken and Terry
2018 Sunseeker 2430S
and if we ever need it, can be pushed by our 2017 GMC Terrain toad (4 wheels down)
Former Georgetown 330TS owner for 10 years with more mods than I can count.
kenandterry is online now   Reply With Quote
Old 11-10-2020, 02:51 PM   #3
Thanks! I found the access panel. It was in the basement.
Old 11-11-2020, 10:40 AM   #4
Wrong on the access panel. There is a winterize setting on the water control panel that bypasses the wh. Before using it, blowout the lines with compressed air as the lines to and from the wh still have water in them.
Dave
2017 Cardinal 3850RL Mocha Pearl full body paint
2016 F350 Lariat 4x4 FX4 SRW CC SB 6.7 Magnetic Metallic
djousma is offline   Reply With Quote
Old 11-11-2020, 11:30 AM   #5
Thanks. I’ve never winterized myself. How and where do you blow out the lines?
Old 11-11-2020, 03:17 PM   #6
Originally Posted by JPSCOTT123 View Post
Thanks. Iíve never winterized myself. How and where do you blow out the lines?
Connect air compressor to city water inlet, set to 50psi. There are adapters made for this. Then run every faucet until just air comes out. Then flip the levers to winterize and run the antifreeze through.
Dave
Old 11-11-2020, 03:51 PM   #7
Here is link to the manufacturers instructions
http://www.bandbmolders.com/wp-conte...structions.pdf
Dave
Old 11-11-2020, 04:41 PM   #8
Thanks! That's what I need.
bypass, cat, heater, location, water, water heater, water heater bypass
