05-02-2013, 12:11 PM
Water pressure regulator
I started to post to a very old thread but thought better of it. Forgive me if this is present already....
I have a 39' 3625 Cardinal 5er and want to replace my inline standard pressure regulator. I'm looking at the brass unit with pressure gage at Camping World. Can anyone give me a 1-5 star on this? I'd like to have more pressure and volume than what I get now. Will the Cardinal handle 45 psi. or can I go higher? Appreciate any and all comments.
T-Man
05-02-2013, 12:52 PM
I purchased the same pressure regulator with gauge from Amazon for less than Camping World. It is adjustable and works great. Your Cardinal can handle 45 psi with no problem, your water pump should be rated at almost 55 psi.
05-02-2013, 01:08 PM
Always Learning
I have no information on that one, but I did spend a pretty penny on a Watts adjustable regulator from rvwaterfilterstore.com. Well worth the $100 for protected pipes and great water pressure!
Checkout my site for RVing tips, tricks, and info | Was a Fulltime Family for 5 years, now we're settlin' down for a spell
05-02-2013, 01:25 PM
Denver, CO
X2
Rvwaterfilter store has several models of the watts adjustable regulators. I agree that a little more $ is a good idea. I once had a line pop of the PEX fitting and it made quite a mess.
The cheaper inline regulators will reduce the flow rate into your unit also.
2017 Fuse 23T
05-03-2013, 04:13 PM
I purchased a cheap one at Wal-Mart and it works fine on my 2010 3625. I have gone without one and loved the water pressure, but I got scared and use the regulator all the time now.
05-03-2013, 04:22 PM
Thanks for recommendations. I also use a cheap inline regulator but prefer more pressure in the shower (As I read, so do a lot of other folks).  . I just purchased one from Camping World. Caught it on a pretty good sale. Hoping a 50-55 psi and increased flow will do the trick. I'll try to update in a couple weeks.
05-03-2013, 04:25 PM
daydreaming about camping
Is it the Camco or the other brand? The camco does NOT have actual pressure information, it just gives ranges in red, yellow or green. The other one (I forget the company name, but I bought one) actually reads in PSI. Amazon sells both and the Camco brand got horrible reviews.
2013 Coachmen Freedom Express 320BHDS pulled by a 2005 F250 King Ranch CC
A rainy day camping is better than a sunny day at work.
05-03-2013, 04:27 PM
Camping World also has the Body Spa shower head on sale that I've been hearing alot about on these forums. Makes great pressure and spray even when there is less pressure. I just ordered one today.
05-03-2013, 04:31 PM
It's the Valatri or something like that. I looked at two sets of reviews. One set hammered it because the gage broke. The other camp gave it like a 4. I looked at the website referenced earlier in the posts. Appear to be excellent quality but they're also very proud of them.
05-03-2013, 04:39 PM
Ill ck the shower head out.
05-03-2013, 04:55 PM
Phat Phrog Stunt Crew
I second the use of a Watts. They are ported for 3/4" and do actual pressure control. They are not a flow restricter like many of the cheap in lines are. If I were you, I would do away with your outside one. I would bet you will see a vast improvement in your shower.
Wayne & Susan Biloxi,Ms
2012 GeorgeTown 351DS...2015 Ford Focus/Brake Buddy
FROG Member
05-03-2013, 05:07 PM
Model for Watts?
05-03-2013, 07:44 PM
Always Learning
N65 sticks in my head- go to rvwaterfilterstore.com and see what they offer. Then email the guy with questions & your number. He'll likely call you. (He called me on a Sunday night when I ordered mine.)
05-03-2013, 09:39 PM
 We have the adjustable one (Valatri) & think it is great. I did have to replace the guage but it froze so did the hose. I just went to lowes & bought a new water guage for about $4 & put it on no problems since...... but I have not had it out in freezing weather. I like being able to adjust the water pressure....
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
05-04-2013, 08:29 AM
The only reason for me I thought of more pressure was for oem shower head, went to the oxygenics and it gives a great shower will little water pressure....save water when dry camping.....I use a pressure regulator and a filter at the incoming spigot...
That way hose stays clean along with camper system....I have not used a filter inside the camper, though keep one for a back up if needed....good luck
2011 Silverado 2500HD 6.0 Gas 3.73
2013 Flagstaff 8524 RLWS
1978 Cape Dory Ketch
05-04-2013, 01:37 PM
Owner/Operator
Does anyone have a good source for the oxygenics shower head (in white)?
I can find them in chrome for a good price, but the ones in white are 3 to 4 times the price.
RodeoGeorge
2013 Rockwood 8289WS
Mods: Central Vac, PI EMS-HW50C, 2025RV, (2) SCS225 Trojans, PD9260, Awning Remotes & LED Lights, Eliminators, External Water Filter,, Intellijacks
2008 RAM 3500 Cab&Chassis Hauler Bed, B&W Companion Hitch
All My Modifications are at this link:
https://www.forestriverforums.com/for...ons-36212.html
05-04-2013, 01:55 PM
shower head
Camping world has them on sale at times for around $25 w/coupon can get for even less....not sure about the internet.....and the white ones are the cheaper ones at CW......good luck.....even at full price is worth the $s
05-04-2013, 02:11 PM
They are on sale this weekend online at Camping World. The white one is $34 and the chrome and brass are like $46.
05-29-2013, 09:32 PM
We have the Valterra (Camping World Item # 49511). Only problem I ever had was that the gauge froze after camping in the snow. I called Valterra and they sent a new one, no charge. I keep the pressure set at 60 pounds. Cardinal Customer Service told me they test the plumbing at 90 pounds so 60 is fine. We use a .05 filter cartridge and still have good pressure.
