Old 04-28-2020, 10:30 PM   #1
What roof do I have
I purchased a used 2017 Cardinal 3250RL, with no documentation, and need to replace the OTA antenna.
I read some roofs are TPO, some EPDM, etc, then read a post today stating that Forest River does not recommend using Dicor on somew roofs.
I'm replacing the whole antenna, which was taken out by a low branch in an RV park.
What should I use to seal the base plate and antenna base?
Thanks, Larry
Alaskaman1 is offline   Reply With Quote
Old 04-29-2020, 09:02 AM   #2
SeaDog's Avatar
Here is a quick video that will explain how to tell which roof you have you can then determine the best sealant for that covering.
Retired Navy
2016 Flagstaff 26 FKWS
Old 05-07-2020, 05:51 PM   #3
SeaDog, I apologize for the long delay, we had a lot of winter leftovers here, I'm just now getting into the antenna repair.
Your link to the video was spot on, thank you for replying, I'm off to install the new antenna soon.
Have a great weekend...if that's possible in this day and age...Larry
roo, roof
