Old 10-28-2020, 07:24 PM   #1
cold weather camping & my neighbor
Howdy. 2016 Shasta 25rs. arrived at rv park last night & it got down to 22 degrees In the morning the city water valve was frozen & the fresh water hose too. Brought in hose to warm it up. My neighbor said their should be a heating wire around valve to prevent freezing. We looked and the extension cord to hook up to box had "grown legs" Good thing I had a cord so I plugged in heating wire and 20 minutes later: water. Then a bit later I had no power to outlets. Checked fuses all good. I went to ask neighbor and he checked shore power cord & the GFCI had tripped. He untripped it and outlet power came on. Moral: Be friendly to your neighbor cause you never know when you're going to need help. Thanks neighbor.
nephi007 is offline   Reply With Quote
Old 10-29-2020, 09:26 AM   #2
SeaDog's Avatar
Its good to have knowledgable neighbors but also good to know your systems for those times no one else is around to help. Tip: if you'er going to winter camp get a good heated water hose.
Retired Navy
2016 Flagstaff 26 FKWS
Old 10-29-2020, 09:39 AM   #3
X2
While cold weather camping brings on a whole new set of conditions to monitor and know about, everyone camping in a R/V should take the time to learn about the workings (and limitations) of their plumbing, heating and electrical systems, regardless of weather.
Days Camped: '17=30 '18=51 '19=58 '20=98
Old 10-29-2020, 10:05 AM   #4
OR---
Keep water in your FW tank and bring the city water hose in at night.
This way you'll have water even if there is no heat cable/tape on park water supply. Many have freeze proof hydrants that drain all the water from the riser pipe when shut off. This allows one to reconnect their "unfrozen" hose and turn on water for that early shower.
Heated hoses are nice but only if the park water supply is properly "freeze proofed". Water in the tank has always been my insurance.
"A wise man can change his mind. A fool never will."
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 10-29-2020, 03:57 PM   #5
Thanks for the advise. Gonna be here 2 weeks then back home to winterize rig and ADCO cover it. Never have cold weather camped only summer and cold weather is definitely a whole new ball game.
Old 10-29-2020, 06:42 PM   #6
dbledan's Avatar
Thanks for sharing! RV neighbors are usually friendly.
I made my own heated hose. Just added heat tape and pipe insulation to a regular rv hose. I left enough heat tape to wrap the spigot too because not all places are smart. I still prefer to use the tanks once it freezes unless showering in the trailer...maybe I just worry too much.
dbledan is offline   Reply With Quote
Old 10-29-2020, 07:24 PM   #7
Hello. I am going back home this weekend ( 4 hours away) and returning to the Shasta on Sunday. While home will buy heart tape, foam pipe and another fresh water hose And will see how it works out. I saw a heated hose for $79.00 but I wonít be here long enough to justify buying it..Thanks everybody.
Old 10-29-2020, 09:06 PM   #8
Duct tape
You will need a roll of duct tape, too. Put a wrap of tape around the foam every few feet or it will gap where the hose bends.
Larry
Larry-NC is offline   Reply With Quote
Old 10-29-2020, 11:40 PM   #9
dbledan's Avatar
Good idea. The pipe wrap I used was sticky. So far so good but.may tape it up just in case.
Old 10-30-2020, 11:42 AM   #10
Great suggestion. You can never go wrong with a big roll of duct tape. Cheers.
Old 10-30-2020, 11:50 AM   #11
nomad297's Avatar
You might want to think about putting some heat tape on your exposed drains and, especially, the dump valves.
Bruce
Old 10-30-2020, 11:57 AM   #12
Yep I thought about those valves freezing & breaking off so Iím gonna wait till around 4pm or so o let the sun warm things up before dumping tanks.. take care guys
Old 10-31-2020, 07:42 PM   #13
Funny..I had read this post & 2 days later, our RV neighbor came knocking on our door to see if we had power. They lost all power. Hubby went to help..told him its good to be a helpful neighbor! At first they thought the 50amp was out, he offered our 50 to 30 amp connector. Seemed to work, but I asked him to go back to chk if the post had a tripped GFI. He went back & 30amp also had stopped, there was a tripped GFi on post. Turned it back on & all seems good.
Gottaluvlife is offline   Reply With Quote
camping
« I can see light | - »
