Old 10-24-2020, 01:33 PM   #1
D Sgt's Avatar
I can see light
I have a Phoenix 29RLS and when the kitchen slide is in there is a hole at the slide corner By the pantry. This appears to be where the slide seals sit/meet. There is a piece of foam on the corner by the couch. Anyone else have this problem? Suggestions? I will try and add pix.
D Sgt is offline   Reply With Quote
Old 10-24-2020, 02:18 PM   #2
Just Tryin' to Help
cboss's Avatar
I'd plug the hole.
If you can see light then water can get in also.
Maybe you could use a little Pond Foam if the hole is not too big.
Craig & Cath
2018 2902WS Rockwood Ultra Lite
2017 Ford F250 Lariat, 6.2 gas
Equalizer Hitch w/ 4-Point Sway Control
Days camped since 2016(retirement): 870
cboss is online now   Reply With Quote
light
