@parisfrance137, I full-time in a 2021 Shasta 18FQ. I have not had any issues with hot water. In fact, the hot water system on this trailer is one of the things I like the most. I can run the shower indefinitely with continuous hot water - as long as I have both electric and propane heaters on and run the shower at ~1/2 throttle (which is still plenty of pressure).
As far as the propane system goes, it will purge the air out of the line on its own. The propane heater will continue attempting to auto-ignite until it finally ignites.
You can run the water heater with both propane and electric heaters running. If you do this, you will heat an entire tank of water in about 10-15 minutes.
The electric portion of the water heater is not on a fuse (fuses are used for 12V circuits only). The water heater circuit is on a circuit breaker (which are for the 120V circuits), which would only trip and you just need to reset it.
If you need any help with anything else, send me a message - I love this little trailer and like I said, I live in it most of the time so I'm very familiar with it.
2021 Shasta 18FQ
2023 Ram 1500 4X4 Lone Star Crew Cab 5.7L HEMI eTorque
Attachment 251949
