Old 06-04-2012, 07:32 AM   #1
A-Frame appliances
Does anyone have the model numbers of the Dometic fridge, heater, coolcat, water heater and pump written down? Just taking an inventory of parts and collecting some online service manuals but my camper is parked in offsite storage so I don't have that info handy right at the moment. If you have this stuff readily accessible and can post it, I'd be grateful.
Thanks everyone.
2011 A-122
rawlus is offline   Reply With Quote
Old 06-04-2012, 09:01 AM   #2
Sorry, don't have them, but I'm going to ask, didn't you get copies of the manuals when you bought your camper? Also, if someone does post the numbers, make sure you verify them when you get back to YOUR camper, your numbers may be different.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 06-04-2012, 09:12 AM   #3
TURBS's Avatar
Thanks everyone.
I would call your dealer and request all your model specific manuals.
Unless you bought your unit privately you should have gotten them during pdi.
Old 06-04-2012, 10:23 AM   #4
I have the paper ones in the camper, I'd just like to collect PDF versions in addition.
2011 A-122
Old 06-04-2012, 03:25 PM   #5
Mostly Harmless
thehamguy1's Avatar
Ok, get ready to write this down ;-)
Dometic Fridge. RM4223
Dometic Heat Pump. 441001 series (many of my manuals cover more than one model; any PDFs you get probably will too.)
Furnace. Suburban models NT-16SE, NT-20SE (I'd guess ours is the smaller one. installation and users manual are separate).
Suburban water heater. Models sw4d, sw6d, sw6de, sw6dm, and sw6dem. I think ours is one of the 6s.
Suburban 3-burner stove model sdn3 (manual also covers sdn2).
Magic Chef microwave MCD990ARS
WFCO electrical panel, manual covers WF-8375p and wf-8740p
Nearly useless stereo CD player model ZX50 (no brand name anywhere on the manual, unless the number IS the name)
I think that should cover it, at least that's all the manuals I had in the camper. Didn't find anything on the water pump and would have to empty the cabinet and take out a partition in there to get at it, so I'll let another buddy on the forum sing out with that.
I think having a set of PDFs of the manuals is a good idea. Wherever your laptop/iPad/whatever is, there are your manuals.
It's never too late to have a happy childhood!
Lee, WU0V, and Courtenay, N0ZDT
2011 Rockwood A128
2000 Silverado 1500 pickup
60W solar system
2000W inverter generator
thehamguy1 is offline   Reply With Quote
Old 06-04-2012, 03:55 PM   #6
Jeep4Two's Avatar
I also had manuals for the axle and some other stuff. I'll look this evening. Camper is up and outside waiting to be cleaned.
Jeep4Two
2011 FR Rockwood Premiere A126 Hard Side
TV=2011 Jeep Wrangler Sahara 2 Dr
Reese 66065 WDH, Curt WDH Shank #17120
Prodigy P2 Brake Controller, Mopar 7-pin Harness
B&M Transmission Cooler (#70268)
Jeep4Two is offline   Reply With Quote
Old 06-04-2012, 04:11 PM   #7
Awesome. When i get all the digital copies together ill post a link for everyone
2011 A-122
Old 06-04-2012, 05:35 PM   #8
got most of them up in a PDF
Its about 15MB in size.
If anyone finds others, let me know or post a link and i will continue to update the PDF...
if you save the PDF locally, you can navigate the different manuals with bookmarks
Dropbox Link for the file as it stands now is: http://dl.dropbox.com/u/36594318/A-F...all_6_2012.pdf
there is a fancier version using acrobat portfolio - makes it easier to navigate each manual, it requires Acrobat Reader 9+ and is not yet compatible with ios devices...
the link for that is here:
http://dl.dropbox.com/u/36594318/A-F...als_6_2012.pdf
2011 A-122
Old 06-04-2012, 08:10 PM   #9
Jeep4Two's Avatar
Ok,
In addition to Hamguy
Water pump: Shurflo 2088/2093 series potable water pump
ESCO trailer breakaway switch ( model designated)
AL-KO AXLE MANUAL. For 2000 a 7000 lbs axles.
Create-A-Breeze - no model designated
Safe-T-Alert model 35-742 combination CO and LP gas alarm
Thetford C-402C / X - C-403L cassette toilet manual (a126 campers only)
Jeep4Two
Old 06-04-2012, 08:13 PM   #10
Jeep4Two's Avatar
Oh --- just found a tiny sheet for the gas regulator.
Cavanga Group - model 528RV Automatic changeover low pressure regulator.
Jeep4Two
Old 06-05-2012, 06:40 AM   #11
Ill add these today, thx everyone...
2011 A-122
Old 06-05-2012, 07:10 AM   #12
The CD player mentioned, model ZX50, that is a Concertone model number. Think they have a website, and have their share of problems. They have their own forum on here.
LadyWindrider
Old 06-05-2012, 07:40 AM   #13
Updated Dropbox Links:
single PDF version (20MB) http://dl.dropbox.com/u/36594318/A-F...ull_6_2012.pdf
PDF Portfolio Version (21MB) http://dl.dropbox.com/u/36594318/A-F...lio_6_2012.pdf
Can someone confirm this is the correct AL-KO Axle manual?
http://www.al-kousa.com/pdf/H52_H60_H70_5200-7000lb.pdf
the other choices are here:
AL-KO Kober - Rubber Suspension Axles
i did not see the 2000-4000lb model jeep4two noted, unless that is the 4000lb model here: http://www.al-kousa.com/pdf/U40_4000lb.pdf
2011 A-122
Old 06-05-2012, 10:16 AM   #14
Mostly Harmless
thehamguy1's Avatar
From your Dropbox to mine! Thanks for thinking of this and making it so easy for the rest of us to profit from your idea!
2011 Rockwood A128
60W solar system
Old 06-05-2012, 12:16 PM   #15
Jeep4Two's Avatar
This is the one I have: http://www.al-kousa.com/pdf/ALKO_2kto7k_OM.pdf
Jeep4Two
Old 06-05-2012, 12:18 PM   #16
Jeep4Two's Avatar
I noticed the website also had spe sheets and parts list for specific drum/brake assemblies. I think you would have to look on the camper axle drum area to know for sure which you have.
Jeep4Two
Old 06-05-2012, 12:41 PM   #17
Originally Posted by Jeep4Two View Post
ill add this - it looks like the manual to cover all torsion axles from 2000-7000 lbs
2011 A-122
Old 06-05-2012, 12:48 PM   #18
anyone got a part# on the porta-potty that comes with the other A-series? (the non-cassette version)
2011 A-122
Old 06-05-2012, 12:56 PM   #19
trudinator's Avatar
They have HAD their share of problems, but they've been very pro-active on getting problems taken care of. If you have a problem with your Concertone, then take it in for warranty work or PM Bob Fields. He can help you out. Not fair for the person who called it "nearly useless" to flame the product without specifics. If you have a problem, take it to the Concertone thread or get it taken care of through your dealer.
2012 Rockwood 8293RKSS
trudinator is offline   Reply With Quote
Old 06-05-2012, 01:03 PM   #20
how about the siding material or the windows?
2011 A-122
a-frame
