We've not added any type of insulation. The heat does come through the bubble windows. We just shut the shades to help keep the direct sunlight out.
The A-frame campers as a whole don't keep the heat out as you can feel the heat on the inside of the roof coming through on any hot day when the sun is out. Same holds true on cool/cold evenings as the inside of the roof gets cold.
I suppose you could cut to size and add reflectix insulation on the inside of the bubble windows to help with the heat but not sure how effective that would be considering you'd be fighting against the heat added by the two huge roof panels that basically act as baking sheets.
Good thing our A-frames come with pretty good AC units and an excellent roof fan!!
Terry
Big Red Camper
"If you always do what you always did, you'll always get what you always got."
2014 Rockwood A128S
2015 Chevrolet Colorado Z71 Crew Cab 4X4 Short Bed
