We just got back from our 1st trip.
From SW Ohio we had stops in:
Stone Mtn. SP –NC
Hunting Island SP – SC
Crooked River SP, GA
And an extended stay at Long Key SP -FL.
We’ve been tent/truck camping since 1972 so this was quite a change.
Towing-
Was pleased with the general ease (Silverado Ext cab 4x4 w/trailer pkg)
Estimate it cost us 2.5-3 MPG
Serious winds (40mph) the last 300 miles or so. I actually think the trailer had a calming effect, keeping the rear end of the truck a little more grounded (it has a cap on the bed)
The A213HW feels longer than I had anticipated, no big deal
Need some mirror extenders
Get a brake controller, you’ll be glad you did (I know the 213 is on the heavy side)
Camping
Comfort was great; love the 6’2” x 6’10” bed
Used the microwave more than we thought
Having the toilet in the middle of the night was a big plus
Exhaust fan is ‘cool’
In general it took us 30-40 minutes to set up/take down
I think everything worked. Even tried the AC for a few hours
Issues (addressing some things I’ve seen on here)
The dealer had to replace the roof actuator before we ever picked it up, but it worked fine
We had rain all day one day (not bad for three weeks) -no leaks while setup
Along with the 40 mph winds on the way home we had serious horizontal rain –no leaks while closed
The counter tops are easily chipped
The toilet sprays a little water out around the rim and onto the floor –haven’t had time to look at that
It has a serious floor squeak in front of the sink –haven’t had time to look at that
The grille is a POS. All the rivets holding the burner in place came loose on the 1st use. Replaced the rivets with SS screws
The heater/furnace can get really loud. I tried working on this before we left; it was better, but not good. We only had it on for 10-15 minutes one morning anyway
All in all, it was a great trip. Really appreciate all the info on this site.
Is the grill the r-v-que that came with mine as well? Aside from the flimsy construction, it never got very hot anyway. I replaced it with a Weber Q1000. I love it so much I now use it at home as my main grill!
2014 Rockwood A122BH
2017 Jeep Grand Cherokee
Use the heater only when dry camping, get a ceramic electric and use that Remember vent when cool outside otherwise will have a huge build up of moisture on the inside.
SFC USA RETIRED
2014 FJ Cruiser
2014 T12DDST
Its Cute but......
Total (2104-2017) 319 2018 (59)
My floor squeak was coming from the cabinet bottom rubbing against the floor which occurred while walking near the cabinet. I put in a wood screw from cabinet to floor which stopped the squeak.
2015 Rockwood A128S
2010 Rockwood 2604
2014 Ford F-250 CC SB 2WD
2008 Toyota Sequoia 2WD
It is made by National Supply LLC Elkhart IN. Seems to get hot ok, just really cheaply made.
I'll make a note of the Q1000 in case I have more issues.
That sounds very plausible. Once I talk myself into going outside -it's 30°f and snowing, I'll check that out.
Did I mention we spent the last 2 weeks where the high was 85 and the low was 72? Every day!
30 and snow...... I told her we should stay longer.
32, blowing snow here. I slept in the camper last night since we had to heat it to keep from freezing the plumbing. It froze up enough to stop the pump two nights ago. Of course I flipped the switch and promptly blew the 10amp fuse.
Warmed it up and no permanent damage. Lucky.
Mark
Michigan
2014 a122s
2014 Tacoma Double Cab My YouTube Channel
Days Camped 2016/2017/2018/2019: 98/106/109/73
