A192HW Sides not fitting correctly
Hi all,
The A frame side without the door (big window side) on my 2014 A192HW is having issues fitting into place. I've used the camper around 8 times since I've owned it and never had an issue in the past until this last trip. The issue is where the pin enters the cavity. It is off and very tough to be forced into place. It looks as if the whole side needs to be scooted about an inch or so to the rear for it to fit. For the time being I removed the pin and I'm able get the locks to attach, but this shows the same symptoms of it being off a bit. The locked towards the front needs to be somewhat forced to fit into the recess and the rear one has excess space.
I've read another thread with this issue and there were mentions of the correct process of setting up and I have tried all combinations of assembly with leveling, stabilizer jacks, and putting sides up. Nothing seems to work.
I have checked the hinge screws which are all in decent shape and the squarness of the camper in general and I can't seem to find the culprit. I have also checked the roof assembly which is fully up and functional at the time this door is attempted to be put in place.
Any advice appreciated.
