We are replacing the curtains in our AFrame, T21TBHW. The hook-n-loop is held on with staples, no glue.
Anyone replace theirs and glue the hook-n-loop? What kind of glue?
I'm thinking rubber cement or hot glue may be more of a mess than I want to deal with.
Suggestions??
One problem with using glue, depending on the type, is the heat in the camper. I tried velcro on the outside and it lasted one day due to the heat. Probably why they used staples or it was just easier for the install. Sorry, don't have a good solution.
Try 3M double sided tape. Attach it to the trailer wall and then attach the sticky side of your hook and loop to the double sided tape. I have stuck a couple of pieces of art to the walls on sailboats and 3M double sided tape NEVER seems to let go. To the point that it will pull veneer off wood paneling before what ever you stuck to it.
2016 Rockwood A212HW
2000 Ford F250 7.3lt 2WD
