10-25-2012, 09:12 PM
#21
I bought a cobalt socket from Lowes, 1 1/16 Six point, lifetime warranty, less than $6.00, used my military discount. On the warranty...now wonder where I put the slip at.
2009 Palomino Puma 25RS
2007 Chevrolet Silverado
Prodigy P2 Brake Controller
10-25-2012, 09:51 PM
#22
You can also buy single sockets at AutoZone. I keep a roll of Teflon tape next to my socket and tape the threads each time I pull it out to drain the heater tank.
Rob D.
10-26-2012, 10:08 AM
#23
Came off like butter this morning! The anode looked pretty good...just some deterioration near the top of the stem. I'll be good to go next spring.
Thanks Again
LM
2012 Flagstaff T-12DD
2004 Chevy Suburban
2000 GMC Sierra Z-71
10-26-2012, 10:30 AM
#24
Thanks Again
LM
Lucky you, I had to barrow a breaker bar to get the anode out. I like the idea in this thread to tighten it just enough to stop the water. So next season I'll find out if I could do that without using the breaker bar. Also the Teflon on the tip was there and I'll replace with a new one.
How much is a anode bar replacement for our aframe and where can you get them?
10-26-2012, 10:59 AM
#25
Flagstaff 22FBS
Gary said that using Teflon tape on the threads (like others have suggested) will help make removal easier. He said our nut end was rusty too. The rod will get replaced before the rust becomes an issue, other than the threads getting rusty and, again, the tape helps somewhat. Ours showed some pitting and corrosion at the nut end, so it will be fine for another season at least.
Deb
Deb & Gary
2021 Ford F150 Lariat 3.5 EcoBoost, 2021 Flagstaff 22FBS
Everybody needs beauty as well as bread, places to play in and pray in, where Nature may heal and cheer and give strength to body and soul alike._ John Muir
10-26-2012, 12:40 PM
#26
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
10-26-2012, 01:50 PM
#27
Originally Posted by herk7769
Cheaper - yes. But you get what you pay for. You won't get much leverage for breaking rusted rods loose with that one.
10-26-2012, 05:26 PM
#28
I think I have seen people use a cross-type tire iron for this before as well. Have not tried mine to see if one of the 4 sockets is 1 1/16"
2011 A-122
10-26-2012, 07:10 PM
#29
He surely put this on as a (Joke)! People using Impact guns,long breaker bars,4 way lug wrenches,then this piece of formed sheat metal? Youroo!!
10-26-2012, 07:20 PM
#30
Yeah - I was thinking that also. I bet Herk smiled when he put that in.
10-28-2012, 08:04 PM
#31
We have ridiculously hard water here and after only one season I replaced mine just to be on the safe side because it showed quite a bit of erosion and pocking.
2012 Lincoln MKX
2013 Rockwood A122BH A-Frame
11-27-2012, 10:35 AM
#32
Unscrewed the anode rod out on Thanksgiving. No problem, looked worn so since it was the original, I'll replace it in the Spring.
