Old 10-02-2024, 08:47 AM   #1
Another DIY shade for ceiling lights a213HW
I have a 2017 Rockwood a213hw. I loved the idea of covering the ceiling lights and tried the original model posted some time ago. I just made messes of heating and molding the plastic. I ended up purchasing Avery Clear Easy View durable plastic dividers. It's perfect becasuse it's very flexible yet not flimsy.
I measured a ceiling light and cut a sheet, allowing for plenty of overlap. You can always trim it down before adding the material.
I had to cut material twice because I didn't leave enough material to roll the edges the first go.
I used spray adhesive to adhere the material to the plastic. Then I rolled the edges and used a small brush to run a thin line of glue to glue the edges down. When I make more (love to change colors and ambience), I will try rolling the edges before adhering the material to the plastic. That may be easier.
I used velcro pieces to attach the shades over the lights. The light switch is still accessible.
ID:	304480   Click image for larger version
ID:	304481   Click image for larger version
ID:	304482   Click image for larger version
Katelyn.Macri is offline   Reply With Quote
Old 10-10-2024, 02:36 PM   #2
This is brilliant! Thank you!
elleimae27 is offline   Reply With Quote
Old 10-10-2024, 11:39 PM   #3
Wonderful post.
Thank you for the ideas and welcome to the forum!!
I'm currently muddling thru adding light myself (Chandeliers??) That allow a reading light over the shoulder while leaning up against the bed's headboard.
The first version didn't get past the dropping and raising the A's and roof.
Power is stolen from the light fixture to power the led bulb.
Happy and safe trail wishes to you.
2012 Rockwood A122, 2017 2018 Kia Sorento 3.3 V6 AWD,
(2012 Subaru Forester with MT & the 2017 Sorento have gone to TV heaven))
Cheers and greetings from a Toronto Canuck
Brandoni is offline   Reply With Quote
Old 10-11-2024, 10:28 AM   #4
PapaGlenn's Avatar
Originally Posted by Brandoni View Post
Wonderful post.
I’ve been thinking about something like this for a reading light:
https://www.amazon.com/WisHomee-Char...07Y9K4L3P?th=1
2021 Flagstaff T12RB
2015 Jeep Cherokee Latitude
PapaGlenn is offline   Reply With Quote
ceiling, light
