11-06-2012, 03:57 PM
Anyone have an issue with the grill too close
when hung? Was advised when I picked up my new 122bh that it discolors the sidewall and affects the decals? any thoughts?
11-06-2012, 04:02 PM
Used one for 5 yrs with no effect whatsoever on the sidewall or the awning.
11-06-2012, 04:12 PM
X2
11-06-2012, 04:28 PM
thank you, I sort of thought it wouldnt be hung there if there was a LIKELY ISSUE with discoloring or other damage. THANKS AGAIN! This forum rocks for HELP AND INFO!
11-06-2012, 05:27 PM
mine sits in the garage ..never used because of the same issue. unlike the other two posters in this thread who do not own our type of trailers, both heat and wind become an issue with an Aframe. Also my popane line to the RVQ .. is way too short .. and the opening frame system which hangs the RVQ on the side of the trailer is basically a poorly designed finger-snapper-offer.
welcome to the forum .. d-mo
2008 Nissan Frontier 4x4
2011 Rockwood A122
11-06-2012, 05:53 PM
X3 on no issue with 2 different campers size/shape of camper should have little to no effect on side of camper. Grills will be the same distance from the wall, they're all hung with the same mounting sys. the key is to now crank the grill up on high for a long time, cook at a reasonably low level and all will be OK
2012 Winnebago "Journey To Insanity" 40U
2008 Dakota Sport 4x4
2004 Subaru Baja - DW's
2006 Honda Shadow Aero - TOAD for now.
F.R.O.G. member
11-06-2012, 08:46 PM
Originally Posted by D-mo
.. both heat and wind become an issue with an Aframe. Also my popane line to the RVQ .. is way too short ..
.. d-mo
Welcome to the forum, TRAVELINBOB!
d-mo, I agree that the hose is too short. However, based on my use, IMO, the heat from grilling was not enough to discolor or damage the camper.
But... we don't like to use it to grill greasy foods or meat like hamburgers or foods that take a long time to cook. We do this both to avoid the mess and potential flameups that may occur. Also, we found that it is easy to suck the smoke from the grill into the trailer and set off the smoke alarm.
David and Jo Ann G. (& Kenzie the Sheltie)
Prattville, Alabama
2018 Flagstaff E-Pro 19FD "Phoebe"
11-06-2012, 08:52 PM
You know if you have a picnic table near by the bracket that the grill slides on to turns sideways so that you can set it on a table top.
The bracket doubles as a stand as well.
I've used mine 6 years with no issues but when really windy I turn the mounting bracket and use it on a table top.
Turbs
11-06-2012, 09:17 PM
bunch of nonsense!
had ours for 6 years now and no such problems.
11-06-2012, 09:46 PM
No problem with ours either, except cleaning it is a pain.
Nigel & Bev
Brit Driver & Canadian Naviguesser
We summer in Cowichan Valley BC Canada & winter in Monchique Portugal great camping in both!
2011 Rockwood Signature Ultra Lite 8280ws 2011 Dodge Ram 3500 4x4 Diesel 2000 Honda S2000
11-06-2012, 10:05 PM
Lots of diverse responses all have good common sense advice, think I will try using it but am now up to date on what to keep an eye on!
2016 BIGHORN 3760EL
2016 F150 SC ECO BOOST
2017 SUZUKI KINQQUAD 500 EPS
11-06-2012, 10:57 PM
You have to wonder why the factory would put the grill bracket on the camper wall if it wasn't a good idea.
But then, my camper is worth well over 30 grand, do I really need to see for myself if it is actually safe?
Nope. Put it on the picnic table.
11-07-2012, 08:13 AM
Those who do not own an Aframe do not understand the logistics of our little campers. Sure with larger campers you do have a windbreak .. but with ours there is little to none, as the back and front roofs slope at 45 degree angle. Add to this the window just above where the RVQ mounts, and if you have a the fantastic fan running it will suck the vapors/smoke right into the Aframe just as a previous Aframe poster reports.
Basically these little RVQ things hard to clean, flare up, and are just a poor idea. This is why you see so many Weber Q 100s and 120s sitting on the picnic tables.
D-mo
2011 Rockwood A122
11-07-2012, 08:17 AM
Easy way to clean your RVQ's is what I do 2-3 times a year, Easy-Off Oven Cleaner cold formula. Just spray the crap out of the grill and let set 2 hrs, then take a stiff brush to it and then rinse clean, gets 99% of grease off body of grill and 80% of burned on gunk on grill grate.
F.R.O.G. member
11-07-2012, 08:24 AM
D-mo
And again you can remove the grill you speak of along with the bracket and turn it into a table top version.
With that said I haven't had an issue with flare ups its a low pressure stove and doesn't really have a big flame.
I use mine a lot and wonder why so many people complain about them so much.
If anyone wants to give there's away I'll gladly take them off your hands .
Turbs
11-07-2012, 09:15 PM
I haven't used mine yet - I can't figure out where to store it when not in use that is out of the way. :P
2012 Lincoln MKX
2013 Rockwood A122BH A-Frame
11-07-2012, 10:37 PM
Originally Posted by thunderroad
i haven't used mine yet - i can't figure out where to store it when not in use that is out of the way.
in the motor home! Duh! :>)
2016 BIGHORN 3760EL
11-07-2012, 11:06 PM
My wife and I use ours for burgers and steaks regularly. We love it.
When traveling it goes in the back of the tv or in the rear storage compartment.
No heat issues for us. We'll continue using in future seasons.
 Jeep4Two
2011 FR Rockwood Premiere A126 Hard Side
TV=2011 Jeep Wrangler Sahara 2 Dr
Reese 66065 WDH, Curt WDH Shank #17120
Prodigy P2 Brake Controller, Mopar 7-pin Harness
B&M Transmission Cooler (#70268)
11-08-2012, 06:20 AM
We don't live our lives by the "what if" mantra. we've used ours for 2 seasons now. No mess on the camper, the awning, and no problem with the decals. If the smoke is an issue with the fan on....turn it off before grilling. Seems like a no brainer.
2012 Rockwood 8293RKSS
11-08-2012, 07:57 AM
In today's sue happy society I would think that the manufacturer did testing to ensure the proper amount of distance (airgap) to prevent any damage to the sidewall. I haven't seen any reports of it causing damage, and I know there's a ton of them being used.
