Old 05-02-2015, 05:18 PM   #21
Blackhat6mike's Avatar
Originally Posted by Timex View Post
Mounted mine in the nose compartment of my Vlite. Got it from Amazon and a 4' auto battery cable(4 gauge) from Auto Zone.
Hope you mounted the switch to also disconnect the parasitics IE: propane, CO2, carbon monoxide and smoke detectors. Also, some units have the outside stereo system "hard-wired" and draw constant power.
These detectors will draw down your batteries much faster than you think.
Sorry but not familiar with the Vlite unit.
That is an awfully small gauge wire coming off your switch. Sure hope that will NOT be the primary power input to your unit.
Aviator Wright Flyer #1919
Army Pathfinder Vietnam, 3 tours
DAV, MOPH, VFW, NRA, 1stCav. ABN
Blackhat6mike is offline   Reply With Quote
Old 05-02-2015, 08:48 PM   #22
Timex's Avatar
The cable "looks" actually heavier than the OEM cable that came on the TT. The little black and red wires you see going to the little white box to the right are the wires that power the booster to my Tire Minder. And yes, this is the very reason I am using the disconnect, to stop the parasitic draws.
2012 Flagstaff V Lite 30 WRLTS
2005 Dodge Ram 2500 5.7 Mag Hemi 3.72 Rearaxle
Nights camped 2015 = 23
Nights camped 2016 = 25
Nights camped 2017 = 13
Nights camped 2018 = 3
Timex is offline   Reply With Quote
battery, battery disconnect
